Steering won’t steer
Old Oct 17, 2020 | 12:21 AM
EBEAR's Avatar
EBEAR
Thanks Seaves this is the kind of thing that concerned me . If they were compatable parts there should have been no need for grinding anything and if you are correct about the tapered spline this is a VERY dangerous combination .
Old Oct 17, 2020 | 04:47 AM
Cowboysculptor's Avatar
Cowboysculptor
Thanks guys. I didn’t realize the shaft is tapered, it must be a very subtle taper. Anyway, as I stated, I have the correct pitman arm on its way, and I’m not actually driving this truck yet, so I’ll have it swapped out soon. Appreciate all the advice.
Old Oct 17, 2020 | 05:09 PM
1956_F100's Avatar
1956_F100
Originally Posted by Cowboysculptor
Well, I got it, and I feel dumb. I put the stock pitman arm on the CPP output shaft, which isn’t notched for the bolt that pinches the mount on the arm tight. (Hope that made sense). In the process of things, I forgot about this, so the arm was slipping on the shaft. I got in with a grinder and gave the shaft a little notch, put the bolt through, tightened it up, and just like that, I have power steering! It feels amazing! Thanks guys.
Glad you found it and it was a simple fix. Not to be critical, but how did you manage to do that? I hope the splines are also locating the pitman arm on the steering box and not just the pinch bolt.
Old Oct 17, 2020 | 05:24 PM
seaves46's Avatar
seaves46
I'm surprised the correct pitman arm wasn't sold with the steering box , mine was .
Old Oct 17, 2020 | 06:41 PM
1956_F100's Avatar
1956_F100
That makes sense.
wahlturfcare
Sep 3, 2020 12:41 PM
Vsanzbajo
Nov 5, 2012 09:13 AM
jle70
Jun 5, 2009 09:26 AM
ozzy1
May 19, 2008 09:03 PM
48 F-2
Oct 14, 2005 06:06 PM
