93' steering issues.
Old Sep 3, 2020 | 07:53 AM
wahlturfcare's Avatar
wahlturfcare
I have a '93 1 ton 4x4 cab and chassis truck(460/5 speed) and recently replaced the steering box as it was leaking and getting stiff.
but now the truck every once and while will jerk the steering around, especially when you make a turn and you have to counter steer it.
It doesn't shake or anything.
I do also have a new drag link, outer tie rods, new pitman arm too. Just can't figure out what could be causing it.
I know the wheel bearings are good, king pins are not loose, and everything seems right underneath.
Maybe a bad steering box?
Old Sep 3, 2020 | 07:58 AM
Kyle Burnham's Avatar
Kyle Burnham
i'm getting a little pissed with how horrible and confusing this sight is to navigate
im having problems with my truck and i have no idea where to begin on how to make a post in this forum
I need help?
Old Sep 3, 2020 | 11:55 AM
GNR22's Avatar
GNR22
I've seen bad power steering pumps (or even pumps that are low on fluid) cause the issue you're describing. If the system loses and gains pressure while steering it can cause the steering to do unexpected things.
Old Sep 3, 2020 | 12:40 PM
My4Fordtrucks's Avatar
My4Fordtrucks
A bad new box is possible. I put a new box on my ‘94 Bronco from Napa and it was worse than the leaking box I removed. Another possibility is the u-joint at the knuckle binding up.
Old Sep 3, 2020 | 12:41 PM
My4Fordtrucks
I need help?
On the left side of the page there is a yellow “new thread” button about a quarter of the way down from the top of the page.
wahlturfcare
Sep 4, 2020 10:51 AM
jgavac
Aug 18, 2020 02:35 PM
9905
Feb 23, 2018 01:12 PM
13MWZ
Nov 24, 2007 05:38 PM
plitz.....
Mar 29, 2004 07:51 PM
