too much wandering
Old May 19, 2008 | 06:29 AM
ozzy1's Avatar
ozzy1
too much wandering
when normal driving my 79 f-100 seems to go where-ever it wants to go .I replaced all tie rods and rod ends steering box power steering pump.... Up on the jack it all seems tight what next... thanks Dave
Old May 19, 2008 | 06:38 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Get the alignment checked - particularly the toe-in.
Old May 19, 2008 | 06:52 AM
ozzy1's Avatar
ozzy1
Sorry I forgot to mention I also did that
Old May 19, 2008 | 07:18 AM
jimlj's Avatar
jimlj
Check where the pitman arm and the steering gear meet. The splines on my pitman arm and or steering box are wore and I have a bit of play there. A bit of play = a lot of wandering.
Old May 19, 2008 | 11:24 AM
Blue Bomber's Avatar
Blue Bomber
i found this on adjusting the steering box
https://www.ford-trucks.com/forums/1...djustment.html
Old May 19, 2008 | 01:06 PM
NOCO77's Avatar
NOCO77
Also check the rag joint, tire pressures, same size tires... does it wander on nice flat areas, like parking lot, or are you checking it out on heavily grooved road surface?
Old May 19, 2008 | 02:42 PM
czaroc's Avatar
czaroc
Check the Trac-bar bushings too
Old May 19, 2008 | 09:03 PM
mudder460's Avatar
mudder460
mine did the same thing on my 77. tighten the worm gear on the steering box. I turned mine down till it was snug and backed it about 1/4 turn. You have to hold the gear with the screw driver when you tighten the nut back down or it will make the gear to tight. It might take you a few tries to get it right.
