Blue spring upgrade question
Old Oct 8, 2020 | 10:07 AM
Timbodiesel's Avatar
Timbodiesel
Was changing out t-stat after thorough flushing ..decided to do blue spring upgrade..however the kit comes with 3 o rings..1 green..1 yellow.1 black..i know the green and yellow go on fuel line adapter..however the third black one is a mystery..watched youtube and every upgrade is on a newer model with no seat..i have an early 03.. so plunger and seat must be replaced..does anyone know where the black o ring goes?? Behind the seat?? Not sure..thanks in advance
Old Oct 8, 2020 | 10:42 AM
Rusty Axlerod's Avatar
Rusty Axlerod
You are correct sir, behind the seat.
Old Oct 8, 2020 | 05:44 PM
Timbodiesel
Thanks rusty..there was no o ring in the old fuel pressure regulator..behind the seat..
Old Oct 8, 2020 | 06:19 PM
TooManyToys.'s Avatar
TooManyToys.
Were you monitoring fuel pressure?
Old Oct 8, 2020 | 09:28 PM
Timbodiesel
just got a new filter cap with brass port..was going to hook up gauge this weekend hopefully..but have not had any other monitor cannot find any on tourque pro.
Old Oct 9, 2020 | 11:51 AM
Visurveyor's Avatar
Visurveyor
There is no fuel pressure pids on Torque or Forscan. You have to buy a cap, as you did or you can use the port on the housing. You would need an adapter to tie in to the housing port. Then you can use an electric or manual guage to monitor pressure.
Mcrafty1
Mar 1, 2020 06:42 PM
fireman660r
Feb 18, 2016 01:17 PM
6ohman2004
May 30, 2015 03:22 PM
Z06MAN
Aug 8, 2010 01:12 PM
frankalonge
Aug 13, 2006 01:56 PM
