Broken Seat Spring
Old Aug 12, 2006 | 09:31 PM
frankalonge's Avatar
frankalonge
Broken Seat Spring
I took my seat apart to replace the upholstery and lower seat pad and came across a broken spring. This isn't the greatest picture of it, but in the bottom right of the picture there is a section that runs up and down. It is broken right by the bend.
Does anyone have suggestions on how to fix this as opposed to getting another seat from from a junk yard? Do you think lightly welding that together would take care of it?
Old Aug 12, 2006 | 09:37 PM
FordBoypete's Avatar
FordBoypete
Welding spring wire turns it into large diameter Bailing wire, or britilizes it so it fails, depending on what type of alloy it is. The real repair would be to find a like kind spring or seat & replace your broken spring with 1 that's not broken.
Or that would be my remedy if I had the problem myself.
FBp
Old Aug 12, 2006 | 11:42 PM
460's Avatar
460
Is that spring easily removable?
Old Aug 12, 2006 | 11:52 PM
frankalonge
It is removable. The seat frame has metal tabs that are folded over the ends of the spring and there are three metal strips crimped over holding it to the coil spring.
Old Aug 13, 2006 | 12:00 AM
460's Avatar
460
I have a seat from a '78 F150 that I'm throwing away. I'll check to see if the spring is good on it. You can have it for the cost of shipping. It is the driver's side?
Old Aug 13, 2006 | 12:19 AM
frankalonge
Thanks! It is the driver's side. I just sent you a PM.
Old Aug 13, 2006 | 01:56 PM
FordBoypete
Way to go Boyz! That's what the forum is all about. . . .Great!
frank'
Dont over bend those "tabs". Just lift them enuff to slip the spring wire out & in again.
Over bending can weaken or break those tabs. Also when you re-crimp them over the replaced spring wire, use a drift punch to set them with a single, "smart", tap in place. They're basically soft & can be easily damaged. Just work slowly & precisely, you'll do fine.
Good Luck on your repair
FBp
Jon5
Oct 29, 2016 05:49 PM
kmjone00
Apr 9, 2016 12:41 AM
chetspencer
Aug 31, 2015 09:57 AM
kestraly
87
Aug 13, 2015 10:51 PM
abe
Nov 12, 2014 09:32 AM
