I have no way to monitor my fuel pressure on my 07 6.0, however I did do the Blue Spring upgrade when I bought the truck about 50,000 miles ago. My question is, does the blue spring upgrade ever need to be replaced? if so is there a time frame for which they are known to be good? Is it common practice to redo the upgrade at a recommended time/mileage? Thanks for any and all replies.
I wouldn't think that the regulator spring would weaken very quickly. I have over 150k miles on my upgraded spring and (after changing my failing fuel pump) I still have good fuel pressures.
That said, there are a number of ways you can develop low fuel pressure:
- contaminated fuel that can restrict the fuel pickup foot or the fuel filters (this can happen anywhere and anytime)
- failing fuel pump (looks like quite a few people get a pump failure around 200k miles)
- leaking fuel lines (or kinked fuel lines if someone sloppy has done work on them or around them)
- regulator problems (more moving parts than just the spring)
IMO everyone needs a fuel pressure sensor and gauge. Injectors are expensive.
I recently replaced my injectors this past summer and the truck has 360k on it (Canada ftw).
No idea on the pump if/when it was done.
What's the best way to go about monitoring fuel pressure? Where to order a gauge or kit from? Keep in mind I'm up in Canada
My blue spring kit lasted four years. And it wasn't the spring that failed, it was the rubber seal around the brass plunger that the spring seats into. My fuel pressure was dropping into the low 40s at WOT. I didn't know until I installed a fuel pressure gauge. It could have lasted less than four years, actually.
I have a nearly brand new fuel pressure gauge for sale if you're interested.
Motorcraft blue spring kit?
Message me with details on the fuel pressure gauge...
I rectified my fuel pressure issues with a sinister diesel regulated return fuel system with under hood mechanical gauge and in cab fuel pressure gauge. Set pressure to 55ish psi at idle never went below 50 at wot. If you want it message me. I'm in Canada.
Thanks bismic, I don't believe I have a fuel pressure problem at this time...I was more concerned if the blue spring upgrade had a known life span and a recommended swap out mileage/time frame. I'm going to look into the fuel pressure gauge set up though, it may be something I will do later toward summer when I start using my truck regularly. I try not to use it in the winters due to the calcium the state uses on the highways here. I use it mostly to pull my fifth wheel now and some traveling in the summer.
Another vote for a fuel pressure gauge - Two years ago I installed a blue spring upgrade, fuel pressure was great for two days, then that little rubber seal folded within itself and fuel pressure dropped down into the low 40s. If I hadn't had the gauge, I'd probably driven the truck until one or more injectors failed, so simply installing the kit without a way to monitor things could put one in a hard place - behind a tow truck.
I didn't have a fuel pressure problem .... until I did. BTW - I was not experiencing ANY issues w/ engine performance when my fuel pump started to fail and the pressure dropped. It still accelerated just fine.
As kgburns posted - how else would you know you were jeopardizing the injectors?
My performance was completely normal too, at least until my truck developed a high-frequency tapping sound at 3000 RPMs. That's when I installed the gauge. The sound is still there, but at least I know my fuel pressure is back where it needs to be. I would bet money that noise is a bad injector.
