Seam Sealer?
Old Oct 6, 2020 | 10:20 PM
cybane's Avatar
cybane
Seam Sealer?
Hey guys,
Working on the front end of my 73 F250 2WD. In the below pictures on the firewall, below the blower hole, above the cab mount, appears to be a caulking or sealant of some kind which is now just flaking off.
Anyone know what it is or what I should replace it with?
Thank you!
Old Oct 6, 2020 | 10:31 PM
meangreen92's Avatar
meangreen92
I used seam sealer on mine. A caulk tube of whatever O'Reillys sells. The original stuff cracked real bad, when that pinch-weld/standing-seam hung up on my bedside, when I was getting my then-new cab out of the bed. The seam bent back into shape, but the seam sealer in that area took a real beating, and I was getting water coming in through a spot on that seam.
Old Oct 6, 2020 | 10:32 PM
ford390gashog's Avatar
ford390gashog
My pick for those types of seams is 3M 08367, stays nice and flexible and its single part.
Old Oct 6, 2020 | 10:54 PM
cybane's Avatar
cybane
Thank you, I will grab some of the 3M stuff and get it sealed up.
Old Oct 7, 2020 | 09:58 AM
tlrtucker's Avatar
tlrtucker
I've heard for years that the 3M sealer is the way to go. Adheres well and doesn't shrink.
Pay attention to the prep. I've heard horror stories about guys seam sealing, paining over it to find a few months later that the seam sealer didn't stick and starts popping off.
Old Oct 8, 2020 | 09:43 AM
ford390gashog
Proper solvent cleaning before seam sealing and warming will give best results. Also remember the 3m is a moisture cure urethane so humidity needs to be above 30% for it to work or you will need to mist it with water.
Old Oct 8, 2020 | 04:54 PM
2dwoods's Avatar
2dwoods
go with 3m you can't go wrong I've used 08050
Old Oct 8, 2020 | 05:58 PM
bluovl's Avatar
bluovl
Real seam sealer that’s used in the factory these days is a 2 part epoxy like this:
https://www.eastwood.com/ew-2k-self-...cartridge.html
I’ve used this type before. Preparation is a must.
Sarge261
Jun 9, 2020 06:53 AM
NDF250
72
Apr 26, 2020 09:49 AM
SwedeinNorway
Feb 26, 2020 09:25 AM
D & D
109
Aug 23, 2016 12:37 PM
Blue Goose
Ford Truck Parts for Sale
Jan 12, 2016 06:21 PM
