Power Steering Fluid
Old Oct 5, 2020 | 11:43 AM
Adam Woolridge's Avatar
Adam Woolridge
About a year and a half ago, i replaced my power steering pump with a rebuilt advance auto one. I used type F ATF per the forums and within the last few months the pump has already started to fail. It makes grinding noises until hot then it whistles. Was this because I shouldn’t have used type F? Should I be using regular PS fluid with these newly rebuilt pumps? I’m going to replace it again soon and want to make sure I use the correct fluid.
Thanks!
Old Oct 5, 2020 | 11:46 AM
ford390gashog's Avatar
ford390gashog
The fluid is irrelevant, the reman is your problem. The reman units are terrible quality (Cardone)and unless you installed the return line filter the pump will also ruin your steering gear.
Old Oct 6, 2020 | 03:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks!
TYPE F ATF is correct for P/S
Old Oct 6, 2020 | 04:46 PM
mark a.'s Avatar
mark a.
It probably failed because of the crap the old pump left behind. I always go through the box after a pump went bad.
irontruck
Jun 24, 2025 11:29 AM
texasjack
Jul 23, 2010 03:15 PM
92 Red F150
Feb 8, 2005 12:39 AM
Wrecker
Oil & Lubrication
Jun 12, 2004 01:41 AM
GoneFishen
Jan 15, 2004 01:00 PM
