Sponsored by: Auxito
Steering column replacement starting issues
Old Oct 3, 2020 | 10:03 AM
Repticake's Avatar
Repticake
I have a 1997 F150 XL Supercab 4.6 4x4
Yesterday we replaced the steering column and I am now having starting issues. We transferred over the key reader and the ignition switch. I put the key in and the electronics come on. If i turn it nothing happens but it doesn't cut out and click like when the pats goes off. I can put the key in the on position and start it at the solenoid but then it starts beeping almost like and alarm, the beeping stops after a minuet or so.
Old Oct 3, 2020 | 07:59 PM
steve(ill)'s Avatar
steve(ill)
you have the shift lever connected and adjusted so the Neutral Start Switch is engaged to crank ?
Old Oct 5, 2020 | 07:27 AM
projectSHO89's Avatar
projectSHO89
A 97 doesn't have a "key reader'.
Most likely, the replacement column has a worn out linkage that connects the ignition cylinder to the switch and the switch simply isn't getting "made" in the START position.
Highway61
Jul 15, 2016 03:08 PM
Redneckrucker16
15
Jul 2, 2014 10:19 PM
smoke1380
Nov 4, 2007 01:35 PM
gaffmedic
Feb 28, 2005 11:11 AM
little rowe boat
Electrical Systems/Wiring
Dec 27, 2004 03:54 PM
