96 f250 5.8 4x4 E40d auto, tranny problem
Old Oct 2, 2020 | 01:17 AM
OBS power's Avatar
OBS power
I'm new to this site & seeking some help. I recently bought this truck knowing it had this problem figured it has to be electric problem. So I paid 1k for the truck it runs & drives but it won't shift 1st or 2nd on its own it seems 3rd & 4th work after. The guy i got it from said he replaced the tranny not sure if it was rebuit or a donor from another, but also the pcm has been replaced before I got it & was the reason the dude was selling it. I've replaced the main wiring on the passenger side tranny which helped the hard shifting but I still have to shift manually. I've pulled codes I'm getting a 621 which says shift solenoid 1 & a 629 for a torque converter code & code for transmission temp switch note sure if I ran the test correctly. The speedo does work but bounces some around 60-70mph.
Old Oct 2, 2020 | 03:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 621 code is why it won't shift. There is an electrical problem with shift solenoid 1. It is either a problem with the wiring harness or a bad solenoid.
Old Oct 2, 2020 | 05:59 PM
OBS power's Avatar
OBS power
Since I've already replaced the solenoid harness to the tranny, so its either a harness to the pcm possibly pinched wire or maybe just a bad solenoid when the replaced the tranny. Like I said I'm not 100% sure which what they did before I got the truck. Just know it supposedly has a new tranny but doesn't maybe rebuilt or from a donor truck & a pcm, I still have the original pcm maybe try that?
Old Oct 2, 2020 | 08:53 PM
Mark Kovalsky
The way to do this is to ohm the torque converter clutch wiring (two wires in the harness) and the torque converter clutch solenoid. If both are good, it's the PCM. Chances are one is bad. The least likely failure is the PCM.
bigblack13
May 14, 2012 09:09 AM
mohare7
Jan 26, 2008 01:59 PM
walt227
1983 - 2012 Ranger & B-Series
May 9, 2007 03:37 PM
walt227
Apr 24, 2003 12:47 PM
Larry1799
Oct 22, 2001 02:41 PM
