Fuel pressure
Old Oct 7, 2020 | 09:51 PM
  #31
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by Visurveyor
Well I think I'm on the pickup foot clean or replace. When I am driving and turn the Corner Swish the tank the fuel pressure drops drastically. Slam brakes and truck fuel pressure goes back up. So I'm thinking that the foot is getting clogged.
What is the easiest way to drain tank. No plug, so I'm guessing some sort of syphen would work. How do y'all do it. I am going to jump on it as soon as I gather as much info on this process as possible. Any easy ways to do this?
Easiest way I've found to get into the tank is jacking-up the front end of the bed. Pull all but the rearmost two bed bolts (leave them loose but threads still engaged) and use a 2x4 to lift it and put blocks between the bed and the frame as you go for safety. And don't forget to unbolt the filler neck from around the cap (3 screws) and the hose clamp that ties it to a support bracket underneath.
Keith Wells
Oct 5, 2020 03:21 PM
fabsroman
Jun 11, 2019 02:09 PM
crop harvester
Feb 28, 2016 02:24 PM
maxum96
Apr 16, 2011 04:43 PM
MustangMatt96GT
Aug 2, 2009 08:37 AM
