Fuel Pressure Issue
Old Jul 31, 2009 | 03:08 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Fuel Pressure Issue
Well after trying to do a fuel pressure shim and it not doing a damn thing but lowering the pressure, I decided I needed to put a real fuel pressure gauge on the truck first....
So here are the at idle and reved up pressures... No shim. But it doesnt matter, with a shim or without a shim its about the same pressure...
What could I be doing wrong? and what would cause such low fuel pressure? The truck runs just fine and drives like it has ever since I got it in january...
http://www.youtube.com/watch?v=IDO8rv5J--8
What is the next step to up my fuel pressure back to a factory level? less than 20 PSI is no where near 60-80 PSI it should be...
Im scared to drive the truck this way...ANd want it back on the road as soon as possible because I dont want to have to borrow a Duramax to tow my trailer early next week..
Thanks
Old Jul 31, 2009 | 11:07 PM
MustangMatt96GT
Bump? i may try and replace my fuel pressure regulator tomorrow and see whats up with that...
Old Aug 1, 2009 | 12:29 AM
kawa's Avatar
kawa
Matt:
Are you sure that you shimmed the FPR properly? If nothing else it may be worth it just to remove the brass cap and make sure that the spring didn't slip off of the centering "Tit" and/or deformed the spring.
Rog
Old Aug 1, 2009 | 12:40 AM
MustangMatt96GT
I have had it apart a few times now... Only thing I can think is the metal piece that is triangular, mightnot be lining up and is pushed out... But the amazing bit to me, is that the truck drives like normal...
Old Aug 1, 2009 | 06:05 AM
WALJON's Avatar
WALJON
Maybe your fuel pump is on it,s way out? did you clean the screen on your fpr?
Old Aug 1, 2009 | 09:29 AM
MustangMatt96GT
Yes, the screen was cleaned too. Where is the fuel pump on these trucks?
Old Aug 1, 2009 | 10:10 AM
WALJON's Avatar
WALJON
It is behind the fuel filter housing and in front of the turbo bolts in the valley and runs off a lobe on the cam in your case under that spaceship looking thing behind your fuel filter housing.
Old Aug 1, 2009 | 10:12 AM
MustangMatt96GT
Nevermind... That's what happens when I post before I'm awake...
Would fuel leaks in the valley cause a pressure issue? Cause I need to fix that too and will do it next week along with a new pump/regulator. I just got to find a regulator someplace.
Old Aug 1, 2009 | 11:16 AM
WALJON's Avatar
WALJON
Yeah for sure bet the pump is leaking out the weep hole and that is your leak and your pressure problem why do you need a new regulator?
Old Aug 1, 2009 | 11:29 AM
pjwoolw's Avatar
pjwoolw
As long as the FPR and fuel bowl aren't cracked they are completely rebuildable. Ed (y2kparts) can get you everything for that. New pump, washers, 3/8' and 5/16" hose (can't recall the spec at the moment) and your good to go.
Old Aug 2, 2009 | 08:36 AM
Oversize's Avatar
Oversize
Matt, call me Ive got a bunch of extra fuel parts filter bowl, regulator pieces etc., left over from the other one I rebuilt recently. I got the entire assembly from a scrap yard to get a few minor pieces out of the lot.
Old Aug 2, 2009 | 08:37 AM
Oversize's Avatar
Oversize
PM Sent....
firemediceric
27
Dec 12, 2009 01:46 PM
YZGUYONE25
May 28, 2009 07:37 AM
Oversize
15
Mar 19, 2009 09:17 PM
John311t
34
Mar 29, 2007 11:16 AM
CAT_man_963
May 16, 2006 08:28 PM
