trans question
Old Sep 24, 2020 | 01:37 PM
moveoverGM's Avatar
moveoverGM
trans question
Hi guys. I have a 1990 F250 with an E40D trans. It wants to go forward in Neutral and works fine in D 1 2 but reverse is non functional. Is there anything I might try with the trans before pulling and rebuilding? Thanks for the suggestions.
Old Sep 24, 2020 | 01:46 PM
jas88's Avatar
jas88
Sounds to me like your manual lever needs adjustment.
Old Sep 24, 2020 | 02:36 PM
moveoverGM's Avatar
moveoverGM
Hi Jass. Would that be adjusted at the trans case attachment itself?
Old Sep 24, 2020 | 03:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Does park work? And will it go all the way to manual 1 and move forward? If so, the adjustment is close enough that it isn't the problem.
Old Sep 24, 2020 | 07:35 PM
moveoverGM's Avatar
moveoverGM
Hi Mark. Thank you for your reply. Looks like Park works fine as does Drive and manual 1 and 2. It wants to move forward in Neutral and reverse does not work at all. Figured we would rule out any simpler solutions before we do to the work of pulling the trans.
Old Sep 24, 2020 | 08:15 PM
Mark Kovalsky
There is no simple solution. The forward clutch won't release. That's because it has welded itself together.
Old Sep 24, 2020 | 08:28 PM
moveoverGM's Avatar
moveoverGM
Mark, thank you. Thought we would ask anyway. looks like we will pull the trans and rebuild. Might be the better option in the long run anyway.
Old Sep 24, 2020 | 09:27 PM
tcollins89j's Avatar
tcollins89j
Had my 1995 motorhome tranny looked at because of a leaky input shaft seal. Once they got it out, there was multiple problems showing on the outside - torque converter was factory installed incorrectly, grease from somewhere slung all inside the bell housing. Decision was made to go the rest of the way through it. Good thing. Clutches had hot spots, etc. Was disappointed because it only had 24k miles on it. Had it rebuilt with a billet converter put in and a shift kit. Tough pill to swallow, but didn't want the headache of losing the tranny in the middle of the Utah desert.
Old Sep 26, 2020 | 12:52 PM
moveoverGM's Avatar
moveoverGM
Hey Mark, is the forward clutch something we will need to order separate from the trans rebuild kit? If so I need to get that right away. Thanks.
Old Sep 26, 2020 | 01:08 PM
Mudsport96's Avatar
Mudsport96
A quality rebuild kit should have everything you need
Mike1
May 28, 2015 08:41 AM
B Big
Feb 13, 2014 08:17 PM
j250hd
Apr 14, 2010 03:57 PM
