Trans Help
Old May 27, 2015 | 12:19 PM
Mike1's Avatar
Mike1
Trans Help
It's a 95 F250 5.8L 5dpeed or 4speed with OD, not sure which Make the trans is. All my forward gears are fine, when I go to reverse, if I rolling slightly forward, it'll do reverse fine, If I come to a complete stop it'll go in feels like about halfway and go to let out on clutch, it pops out and grinds. If I push clutch 2 or 3 times it'll go into gear. So I'm thinking, Master Cyl, Firewall flex? or trans reverse is shot and needs rebuild...any suggestions?? Thanks
Old May 27, 2015 | 12:51 PM
GoinBoarding's Avatar
GoinBoarding
It should be a ZF-5 trans (if factory original). Sorry, I'm no help otherwise.
Old May 28, 2015 | 08:41 AM
Mike1's Avatar
Mike1
Thanks, i'll climb under it today and hopefully get the numbers off of it. As soon as I can get this Mustang sold out of my driveway, I have a Scion TC that needs to have all four corners done for suspension and rotors, then I can pull the truck in to drop the trans, I just don't know if it would be cheaper to put another trans in or to repair this one, or if the trans is even the problem.
Thanks
Colebreed21
1997 - 2003 F150
Nov 15, 2017 07:11 PM
homesteader
2004 - 2008 F150
Dec 28, 2011 09:42 AM
swooshcmk
Nov 8, 2007 04:59 AM
Bill_Beyer
Sep 21, 2001 05:35 PM
