Lifted 2004 Angle problems
Old Sep 22, 2020 | 11:06 PM
Shane.606's Avatar
Shane.606
Hey guys my 04 f-150 before I got the truck it had a lift on top of the springs put in and my cv axel and ball joints and every Down there is all wore out cause the angle is bad. Is there something I can do to fix this?
Old Sep 22, 2020 | 11:51 PM
3Prcntr's Avatar
3Prcntr
Get a proper lift? You got a leveling kit and you probably went too far with it. I have a 2" one on mine, but most people seem to think that 2.5 or 3 is level when that is way too much. How much of a level do you have and did you get an alignment done afterwards? Were those parts already going before the leveling kit was installed? Did you replace anything else? I have been rolling on 2" level for 30k miles, but I also replaced literally everything from tie rods to hubs to control arms and brakes included. Everything. So if the angle is bad an causing premature wear, the solution is to fix the angle and replace the parts.
SCFlareside
Aug 22, 2018 04:50 PM
2014denimstreetglide
2004 - 2008 F150
Apr 3, 2015 06:57 PM
67vdubya
2004 - 2008 F150
Jan 8, 2007 04:31 PM
whiteboy rick
2004 - 2008 F150
Aug 9, 2004 09:53 AM
dgdee
2004 - 2008 F150
Jan 5, 2004 01:58 PM
