How hard is alignment after leveling kit?
Old Oct 10, 2017 | 10:54 PM
SCFlareside's Avatar
SCFlareside
So I've been considering a very modest lift with the truck ('85 Flareside 4x4 F150).
Would rather not go with harsher springs / aftermarket, and thinking about either 1.) a leveling kit or 2.) 2" spacers on the front, with a 2" lift block in the rear.
My question is this - has anyone had issues with the alignment using a 1.5 to 2" lift / leveling kit in the front?
Looking for wisdom from those who have been there.
Thanks!
Old Oct 11, 2017 | 06:02 AM
Franklin2's Avatar
Franklin2
Lots of people do have alignment issues when the ride height is changed on these trucks. If they can get it in, expect new eccentric bushings ($60) and a full alignment, all total at least $150. I bet they can't get it in with a 2 inch lift.
Old Oct 11, 2017 | 10:39 AM
SCFlareside
Thanks for the reply Franklin, good info -
I was wondering if maybe 1 1/2 inches front would be a better idea. Sounds like it's worth avoiding the 2" spacers.
Anyone else with experience, or who has managed to get things back into spec at 1 1/2? Leveling spring recommendations?
Old Oct 11, 2017 | 06:59 PM
reamer's Avatar
reamer
you'll need Radius drop down brackets to get caster, and drop-axle pivot brackets to get the axle arms parallel to the road....
Old Oct 12, 2017 | 09:25 AM
Chevra's Avatar
Chevra
I went with the Rough Country leveling coils on my 2WD. I was able to get it back within spec after they settled a bit. I have never worked on a 4WD model so I don't want to give you bad information on what I did to mine to get it back into spec. But I can say that the Rough Country coils ride nice in my opinion.
Old Oct 12, 2017 | 09:39 PM
DeereFord300's Avatar
DeereFord300
Leveling springs are a luck-of-the-draw situation, if you're looking for guaranteed no-trouble, I would look for a full lift from a reputable company (BDS, JBG, Wild Horses), like this one:
1980-1996 Ford F150 4WD 4" lift kit 501H | BDS Suspension
Old Oct 13, 2017 | 12:23 PM
Nodrama's Avatar
Nodrama
I am going with a 4" complete system on my 83 F250HD. I do not want to fight to get the alignment correct. That and I am wanting to run 35's as well.
Old Oct 13, 2017 | 10:21 PM
Franklin2's Avatar
Franklin2
For no drama, that is the best way to go
Old Oct 14, 2017 | 02:02 AM
Nodrama's Avatar
Nodrama
I try to live it...."no drama"....lol
Old Aug 21, 2018 | 10:47 PM
mhoefer's Avatar
mhoefer
Trainhornman, you want your alignment report to look like Josh’s, and CBEllis post with the parts to be installed. Ps you guys are great, ideally Trainhorm lands caster into the plus 4-5 degrees range with this help.
Old Aug 22, 2018 | 08:40 AM
CPow94's Avatar
CPow94
I put a 2.5" complete RC system (with rear leafs) on mine. I still need shims to get the camber right, but it's nothing detrimental to me as it's not a daily driver and when I do drive it, I'm mostly in the dirt/mud. Toe and caster aligned out just fine. Although keep in mind; The complete kit does come with radius drop brackets and I-beam drop brackets, so if you're just looking to space, you'll have to find a solution for those brackets. Dropped pitman arm and longer brake lines are not needed.
Old Aug 22, 2018 | 04:50 PM
Franklin2's Avatar
Franklin2
There are no shims to get the camber right. The caster and camber are done all by the same eccentric. Since you went so high without any brackets, you are probably out of luck. Usually 1.5 inches is the max for the bushings.
camo86
May 24, 2012 05:29 AM
HowieF150
2004 - 2008 F150
13
Jan 31, 2007 04:21 PM
Mudrover06
1978 - 1996 Big Bronco
Feb 14, 2005 06:50 PM
rsadajar
2004 - 2008 F150
Jun 14, 2004 11:06 PM
