high idle issue.
Old Sep 21, 2020 | 08:15 PM
powersfab's Avatar
powersfab
high idle issue.
my 92 4.9 never comes off hi idle.
no vacuum leaks found.
coolant temp sender ohms out correctly.
if i un-plug the idle air bypass rpm drops to lo idle.
any ideas?
Old Sep 22, 2020 | 01:25 PM
jas88's Avatar
jas88
IAC valve is malfunctioning. Is it a Motorcraft valve? The aftermarket ones that some folks use are crap in my experience.
Old Sep 22, 2020 | 05:26 PM
ZombieF150's Avatar
ZombieF150
Has someone janked with the IAC set screw? thats a no-no , if not that the IAC is probably in need of replacing.
Old Sep 23, 2020 | 06:50 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by ZombieF150
Has someone janked with the IAC set screw? thats a no-no...
IAC set screw? There is no such thing that I’m aware of. Are you talking about the throttle stop screw?
Old Sep 24, 2020 | 08:52 PM
ZombieF150's Avatar
ZombieF150
Yes.. my bad. Too many hours working and not enough sleep.
Old Sep 25, 2020 | 07:27 AM
rla2005's Avatar
rla2005
When you unplug the IAC the idle RPM should drop way below normal or stall out. If the idle RPM remains high or what would be consider a normal idle RPM then you could have a vacuum leak and/or someone has previously jacked with the throttle stop screw.
jed1894
24
Jan 13, 2016 08:34 PM
greg213187
Jan 28, 2011 01:24 AM
Afireinside2285
Aerostar
Aug 5, 2009 06:42 PM
twinarrow99
1983 - 2012 Ranger & B-Series
Sep 12, 2006 09:30 PM
