Is this 12V conversion kit missing something?
Old Sep 21, 2020 | 06:43 PM
Mixer man's Avatar
Mixer man
Originally Posted by ALBUQ F-1
3-wire alternators require a resistance in the Field wire in order to trigger the regulator to start charging. The light bulb provides that.
All you need to do is rev the engine a little and the residual magnetism in the iron core rotor will start the charging. Of course if you don't like to bump the throttle (who doesn't?) then you would need the light or an equivalent resistor hidden out of sight.
Old Sep 21, 2020 | 07:19 PM
Scott M-47's Avatar
Scott M-47
I think I’m going to pull the trigger on this kit, still a little pricey but I was planning on going with the electronic ignition again like I currently have on my truck now. I’m not confident in how I’m going to wire everything but I’ll have to learn somehow - https://www.vintageautogarage.com/19...-p/f4953ek.htm
fordf11948
27
Sep 3, 2017 08:29 PM
91 Nite
Aftermarket Products
May 23, 2017 01:51 PM
JT250
17
Dec 25, 2015 01:04 PM
azzy522
Nov 27, 2004 11:16 AM
Nathan
Mar 7, 2002 09:02 AM
