EGT Numbers
Old Sep 21, 2020 | 10:03 AM
Ford Firefighter's Avatar
Ford Firefighter
Okay awesome! I’ll get a new filter then!
I wanted to pop for new injectors and a tuner at the same time but I guess if I get a Hydra I won’t need to send it in when I get my injectors!
Is the Hydra what y’all would recommend for my application? I know I’m probably asking a 100+ thread question that’s already been discussed a hundred plus times! So is there a link y’all could post for me to hit?
Old Sep 27, 2020 | 08:49 AM
Tomkat07's Avatar
Tomkat07
Originally Posted by Ford Firefighter
Thanks for the help!
No typo lol idle is actually at two thousand degrees!
I have made a boost leak tester and I can’t find any leaks!
And yeah I didn’t realize how smelly the CCV gas was! I think I’m going to run the hose further past the cab!
My idle temps settle at around 350* at idle, E99 F350 7.3.
Chris
Old Sep 27, 2020 | 03:42 PM
RA101725's Avatar
RA101725
Banned
Originally Posted by ESwift
200-225 is lower then they should idle, 300-350 pre turbo is about the lowest normal idle temps you would see
i looked at it again. Around 300 or so stopped at a red light warmed up, but it slowly cools off under extended idling.
Old Sep 27, 2020 | 10:16 PM
timmyboy76's Avatar
timmyboy76
If you can hit 1200* being stock, id steer clear of any tunes til you get them temps under control
Old Sep 27, 2020 | 10:31 PM
Ford Firefighter
Okay! Thanks for the advice y’all! I’ve ordered a new filter and pre filter, it’ll be here Friday. I’ll tell you how it is after that!
Old Sep 30, 2020 | 03:38 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
After a 25 mile trip towing our 5th wheel, the idle temperature settled just under the 300* mark on my ISSPRO pyrometer gauge with the probe in the driver side manifold. The truck had been idling for about 10 minutes before the reading was taken while backing the 5th wheel into the site and then unhooking to park the truck.
Because of this thread, I wanted to make note if the EGT reading at idle after the truck was worked.
Old Sep 30, 2020 | 06:14 PM
Wes444's Avatar
Wes444
250-275 at idle here. After driving a while it's around 300* for 30 seconds and will drop back to this range before shutdown
Old Oct 1, 2020 | 09:30 AM
RA101725's Avatar
RA101725
Banned
That’s about right after double checking mine. As high as 350 or so when it’s hot-hot at a red light and cools off from there if you let it idle for awhile. Not something I normally paid much attention to. On a cold start it will only be around 200 when it lights.
Old Oct 2, 2020 | 04:13 PM
Ford Firefighter
Originally Posted by Sous;[url=tel:19503923
19503923[/url]]After a 25 mile trip towing our 5th wheel, the idle temperature settled just under the 300* mark on my ISSPRO pyrometer gauge with the probe in the driver side manifold. The truck had been idling for about 10 minutes before the reading was taken while backing the 5th wheel into the site and then unhooking to park the truck.
Hey thanks y’all for your input and advice! Just slapped on the Donaldson 6637 and that made a good difference! I’d say 50-100* cooler than before and it seemed the past week before the filter arrived, the EGTs slowly got cooler throughout the week?? Maybe the turbo “breaking in”? IDK! But anyway thanks again!
owenstout
Aug 3, 2010 08:50 PM
owenstout
Nov 2, 2009 07:17 AM
fordmanfox
Mar 12, 2007 03:25 PM
Pigeon
15
May 12, 2006 08:25 PM
RodanAZ
28
Mar 19, 2005 01:02 PM
