Cracked piston
I was just saying you would for sure have more towing power with an automatic than a standard is all.
I've looked at the sae adapters on idis before, I think a person could cut off the mounting ears from it and build some sort of trans mount. Otherwise it would be almost impossible in a pickup because the exhaust manifolds go the other way, which would contact the drive accessories, can't use pickup manifolds because of start location
I know you're probably thinking why in the hell anyone would want a twin sticker in 2020, and honestly, they're narrower, built like a regular transmission therefore easy to rebuild.
I don't have the wheelbase to go industrial with a regular cab 4x4. If I did I'd get a divorced 203
It's alot of work, but hey, build what you want so you don't have to settle for what you buy.
Thankfully I don't tow much, but if I had a rig that would tow better I probably would find myself doing it more.
Some pictures I managed to snag while I was checking this thing out, it was at an auctioneers place, he claimed nobody ever bids on it. I wasn't financially available to put an offer on it and it didn't seem like I would do me much good with the way everything was setup. Motor had been spray painted too.
Unsure of what transmission that is, I'm assuming a Clark or something of the sort.
But I doubt I'll need anything stouter. I don't think the 150+ pumps are very streetable/towable.
I definitely trust this local guy more than either valair or southbend, they're just a name from what I gather, I'm sure they do some r&d on what they sell, but I'm sure it's also trumped up a bit by what this guy said.
Disc didn't come in today. We'll see what it looks like when it does. I noticed the disc they sent me the first time looks identical to a luk disc.....
I also read apparently all the pressure plates are basically the same, just a matter of who's name if any is stamped on it. My boxes from valair have been painted (yes painted) black, which tells me they're generic boxes, either for them to put stuff in, or maybe these kits come from someone else and they're too cheap to slap a logo on it. Absolutely nothing was labeled or stamped anything at all other than a sticker for the flywheel side of the disc...
My exedy kit (partner company to southbend) that I ran with the t19 actually had a wider friction disc and pressure plate than what I've received so far. Pressure plate was stamped luk
The local guy told me even though the pressure per sq inch is lower with a wide plate and disc, they don't heat up as much if you do slip it and seem to last ALOT longer than the narrow stuff.
He basically said that #3200 pressure plate is about all you can fit inside the zf5, I could theoretically stack two engine adapters and move the trans back an inch, and that might be enough to do something different, but id need a custom input shaft so it stays in the pilot bearing. Either that or have it built onto and remachined. Either of which would probably be fairly expensive.
He said southbend has custom flywheels made for thier dual disc setups that hug the motor more so you get more room. That and the flywheels are stepped to swallow the first disc and intermediate plate. So it's basically the same protruding length as a single disc.
I really wish I could get a twin disc clurch with steel backed organic discs but it looks like it's out of the equation for now. Until I get another wild hair and want to attempt the impossible once again..
The 150cc is fine, the 180 is a bit less friendly.
I reached out to a few different companies last night but none of them made custom input shafts, only sold performance ones. But....I had an idea, cut the stock on, extend it an inch and have it friction welded. So I also reached out to several places that do friction welding but none of them do one off stuff, only production runs of products.
But I think one could possibly have the input lengthened and friction welded, stack two spacers on the back of the motor, and maybe have enough room for a dual disc clutch. Even if you had to stack three adapters, it would technically work as long as the input shaft was long enough. Driveline modifications would be minimal or non existent at one inch, maybe just a slight trim and reweld at two.
Still waiting on my replacement disc
you could add a spacer to the crank and not have to modify the input shaft ... possibly.
But yes...IF I had a good lathe, and the plan is once a shop is built to store it to have a lathe and a mill. I'd love to have a powered rotary table where I could turn my own flywheels as a lathe big enough to chuck one up would be out of my price range not to mention power requirements.
Back to the drawing board for now, but I really appreciate the input, I'm sure some company could make me a custom input shaft, but weather or not it would be cost effective is another story.
image for example...
Still no clutch disc
Disc was a copper or brass backed disc, local guy told me steel backed is the best. This is also the only clutch valair sells for an idi. I just slapped it in...
Got the trans under the truck then had to figure out a way to get it up on the trans jack. Couldn't find any ratchet straps, just a couple of the straps missing the binder so I tied one side to the frame, pulled it as tight as I could and tied it. Worked pretty well actually
Got it on the trans jack and strapped down, ended up having to pull the carpet back and loosen most of the tunnel hat. Then I was able to jack the trans high enough and got it stabbed first try, all the bolts went in easily by hand. Sure was glad it didn't fight me...
I will have to modify the tunnel cover a little bit, but it should work and hopefully my early style transfer case shifter will work, it looks like it should. My trans came from a 93, 92+ don't have trans tunnel covers, so I wasn't able to get a zf specific cover.
Now, onto the cross member, I believe the zf one was a 2wd member, since even though the trans was 4x4, it was a 2wd f-superduty. So it doesn't have the lower portion for the front driveshaft, nor the low profile driver side crossmember horn.
So, the t19 mount, bolts right to the zf5, and let's me use the t19 member. But I'll have to drill new lower holes on each side, the uppers catch on one and I'll probably just do that for now until I can get my hands on a ninety degree drill..
Got dark and cold so called it a day, clutch is in, trans is stabbed and bolted, slave cylinders on, and reverse connector is plugged in (it was the same)
Til tomorrow..
Drug the transfer case under with me and put it on my chest and stuck it up there. Mated up without a hitch, even the dowel was in the right spot. The zf also has a dry tailshaft, my transfer case has an input seal, so these should never accidentally share fluids.
The pivot bolt for the 4wd shifter was standard threads, the zf seemed to be metric, luckily it was a 9/16 coarse so I jusk took the tap I used for the bigger head studs and ran that in there and it bolt fit and held. It didn't take much off. I'm thinking it must have been m14 with a very similar pitch.
This is the t19/bw1345 shifter mated to the zf, plenty of clearance
Had to bend/tweak the original linkage piece
The original linkage is straight, and the offset for the shifter of the zf is spaced out towards the frame more. I tweaked it like this and got lucky that it fit perfectly. Transfer case shifts nice and smooth, no binding.
Got the drive shafts mounted up and was down to the last thing. Exhaust that I removed..
This reinforcement ear had to be removed so my hot pipe would fit (custom hot pipe)
When I originally tried a banks turbo kit, I couldn't for the life of me bend the firewall lip down. A year or so ago I remember having a conversation with an obs powerstroke guy, he told me he cut slots in the seam with a sawzall and that make it easier to fold it down so I also did that for extra clearance, and I'm glad I did because the zf bell housing sticks out/back more than the t19.
So, my intermediate pipe fits nicely. But won't line up with the lower pipe, so tomorrow I'm going to put it a mile down the road to the welder and add an extension piece to that and then it'll be all buttoned up and ready for round two.
Hopefully this transmission ends up being good. If not, at least all the conversion stuff is out of the way.
Also it fits TIGHT to the original floor pan, I used a pry bar and tweaked it for as much extra room as I could get. If I have to add a zf floor pan later I will. For now it will look all factory,
I was also able to mate the shifters together, I removed the upper t19 shifter, beat the square part flatter on one side to oval it, it fit real snug, I then drilled a hole in the t19 shifter for one bolt to go through the zf5 lower.
So tomorrow I have to pick up some stuff off the truck, throw the kickpanels and floor mats back in, weld up the exhaust and then I'm hopefully finally done.
It's also gonna take a good day or two to get all the tools organized and back into this truck.
