BTS trans installed
Old Dec 30, 2020 | 10:08 AM
  #31
Abinsur's Avatar
Abinsur
I'm at about 5K miles on her, and towing a 9K dry trailer every other weekend. I'm towing in 3rd at 2500, 62-64mph, and she is just awesome. Loaded down, I'm guessing I'm at 10.5K. Pulled a very tall grade twice this last month and she rocks. Shifts fast and firm, but never jarring, even on that grade. Hasn't hit over 180'-ish so far, that I've seen. Generally right around 160-170'. Still loving her; more every time I tow.
Old Dec 30, 2020 | 12:00 PM
  #32
BWST's Avatar
BWST
Got Data?
Originally Posted by Abinsur
...He specifically told me to take it out, get up to some speed, then downshift it a gear and let off the throttle. He said, "You can use my trans to help brake the truck, but you need to go see for yourself. Once you do that and the truck slows, let it get slower and drop it into 1st. You'll see the nose of the truck dip down. It'll help coming down a grade or hill when you're towing...
How does the BTS do going downhill with your trailer? Do you find you'd like an exhaust brake or does the engine and a few taps on the service brakes get it done for you? The latter has worked for me so far, but I'm only towing 9K loaded.
Old Dec 30, 2020 | 01:19 PM
  #33
Abinsur's Avatar
Abinsur
There is definitely more resistance in downhill sections, Jeff. It's nowhere near an exhaust brake, though. I don't have to ride the brakes, but I will reach down and finger the trailer brake controller lever. It was a decent grade, @ 15-20 minutes at 4-6%. With the stock trans, I would have absolutely had to use the service brakes and trailer brakes to keep her reasonable.
Old Dec 30, 2020 | 05:29 PM
  #34
BWST's Avatar
BWST
Got Data?
That is an improvement. It is nice to just tap the trailer brakes with the controller if that's all it takes. Good to hear. You've got all the mods you need at this point it seems, based on your signature, for a great tow rig.
Old Jan 4, 2021 | 01:58 PM
  #35
Bonanza35's Avatar
Bonanza35
Abinsur, do you have a thermostat on your trans? Just wondered, I hardly ever see 160 or 170 on mine with the 6.0 cooler. Those are good temps you have.
Old Jan 4, 2021 | 03:34 PM
  #36
Abinsur's Avatar
Abinsur
I don't know, Bonanza. I didn't replace one or put one in, but if it has one OEM, then it's probably still got it somewhere. I didn't see one when I put the cooler in, however.
Old Jan 4, 2021 | 03:58 PM
  #37
Brother Les's Avatar
Brother Les
TransTemp gauges were not OEM
Old Jan 4, 2021 | 04:15 PM
  #38
Eaglescout94's Avatar
Eaglescout94
I can and have seen around 170 with mine but that’s going through the OBD2 port which I was told will read about 10° hotter than a gauge at the pressure port. Ive got the smaller 6.0 cooler and the lines are routed through the main radiator like factory.
Old Jan 4, 2021 | 04:49 PM
  #39
Abinsur's Avatar
Abinsur
I'm planning several trips with the family out of CA this year. Our first trip will be either to AR by way of central TX, or up through ID and down to TX. We haven't made up our minds yet, but the first trip is set for 2 weeks in April. She's getting us prepped to leave for good, but we need to explore a bit before we commit to an area. I'm going to keep a written log of what we did and how she performed loaded down (the truck, not the wife).
I'd be lying if I said I was comfortable with a 4-5K mile trip and a 225k mile truck, but I've saved for, swapped out and bled installing most of the stuff I figure could be the major breakdown points. I've got good kids and a good wife, but their confidence in my mechanical abilities coupled with their ignorance of how many millions of things could go wrong give me heartburn just typing this. When I express any hesitation to her, she says, "It'll be fine. You just spent $6K on a transmission. What else could go wrong?". I smile and mumble under my breath, "...a lot...".
Old Jan 4, 2021 | 05:12 PM
  #40
Bonanza35's Avatar
Bonanza35
I know what your saying with the miles. But all the reading I do on here kind of makes me forget about it. I say it is a diesel, what could go wrong. We would of went a cross the US this year if the Covid thing didn't hit. Hopefully this year might be different. I have the smaller Ford 6.0 cooler and hardly ever see it above 140 degree's is why I asked. Did BTS install, I don't remember. But then again he would of told you if he install one.
Old Jan 4, 2021 | 05:14 PM
  #41
Abinsur's Avatar
Abinsur
I put it in myself, Bonanza. I didn't see anything from Brian about a thermostat or needing to replace/install one, so I just bolted the trans in, flushed the cooler and filled it.
Old Jan 5, 2021 | 03:22 AM
  #42
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
They were in 2002, they replaced the voltmeter.
Old Jan 5, 2021 | 07:20 AM
  #43
FordTruckNoob's Avatar
FordTruckNoob
There is a post on this forum from @Mark Kovalsky that said something like "the design operating temperature of the transmission is 180⁰F". That's why a lot of us run one of these..
Running a little cooler doesn't hurt anything. It's just not as efficient as it could be.
Old Jan 5, 2021 | 07:59 AM
  #44
BBslider001's Avatar
BBslider001
My man, you have a great wife and kiddos.....myself included. Do you know how many times on here I see the proverbial "gotta run it by the wife" or "the wife is griping about all the time and money it takes"??
My wife is very similar to yours.. If I say "the truck needs such and such" before a long trip, she doesn't even blink. She knows I am doing the best for my family and has all the confidence in me to fix it/male it better. She is a gem and never gives me a hard time about truck stuff, or anything really....and this is coupled with her and my experience of being on the side of the road more than once with major mechanical problems. I appreciate you sharing....she is a gem for sure. Count those blessings. And yeah, she's probably right. You'll be fine, and even if something does break, you have the ability to handle it and a good community here to back you up. Holler if you need.
Old Jan 5, 2021 | 08:43 AM
  #45
SkySkiJason's Avatar
SkySkiJason
Brian once told me there is no need for t-stat or additional filters. I specifically asked about coooooold weather and I think he said if the fluid is cold enough it won’t flow through the coolers well and will use the bypass. He was not worried about low temps at all.
Makes me wonder about the place that allegedly deletes the bypass.
