Casting flash in head water jacket
Old Sep 13, 2020 | 02:01 PM
Millam's Avatar
Millam
This is the second time in 40 years that I've run into this problem. So it's not that common. But these heads left the factory and have been rebuilt at least once with nobody noticing the problem.
I had an engine long ago that would overheat and I had a hell of a time trying to fix the problem. Eventually I decided ti pull the heads and found a chunk of casting flash much like that in the picture.
At that time I decided to always port the entry of the water jackets. I do both ends.
This is the piece that I removed.
I don't do much to the entry and it only takes a couple of minutes.
I'm of the opinion that improving the flow of coolant even a little is good Karma
Old Sep 13, 2020 | 07:07 PM
fe390pc's Avatar
fe390pc
I have found casting flash to be a common issue in the block, have never seen it in a head before.
Old Sep 13, 2020 | 07:20 PM
v84960's Avatar
v84960
Oy, good to know. Never thought of porting coolant passages, but it makes sense. Easy to do and could help a little at least.
Old Sep 13, 2020 | 07:22 PM
fe390pc's Avatar
fe390pc
Also just rinsing power washing out the block. My block had been hot tanked, and the amount of sand and flashing I found was crazy. So glad I decided to wash it again prior to assembly.
Hartwig
Oct 23, 2020 02:36 PM
pintoplumber
Mar 11, 2019 11:03 AM
Bmoodie10
Jun 10, 2018 11:42 AM
F250racer
General Automotive Discussion
May 3, 2010 02:29 AM
dustinova
Nov 13, 2007 09:37 AM
