Bigger injectors?
Old Sep 7, 2020 | 02:23 PM
kevinv10's Avatar
kevinv10
Bigger injectors?
Admittedly, I don't know much about the voodoo behind injectors. I have a 94 with a 460. Just rebuilt the motor, .030 over. Installed comp cams #:34-255-5, and complete banks system, headers to tailpipe, no converter. Deleted the air pump and all associated piping. Timing right now at 12°. Has a little bit of a lopey idle, small surge while low speed driving. With these new mods, should I increase my injectors a little bit? Or assume computer will compensate?
Thanks
Old Sep 7, 2020 | 04:28 PM
Conanski's Avatar
Conanski
No the computer can't compensate and the stockers are good for 300hp so nothing needed.
Old Sep 7, 2020 | 04:58 PM
kevinv10's Avatar
kevinv10
conanski, do u mean computer can't compensaye for cam and headers? Thanks for info on injectors.
Old Sep 7, 2020 | 05:24 PM
Conanski's Avatar
Conanski
No.. it can't compensate for bigger injectors.
Old Sep 7, 2020 | 05:26 PM
kevinv10's Avatar
kevinv10
thanks Conanski for the input.
Old Sep 7, 2020 | 06:07 PM
torq'ta 5 8's Avatar
torq'ta 5 8
check for codes,could tell you if its lean, with o2 sensor code, check IAC, and TPS.
How to Clean and Test your IAC - Ford Bronco Forum
Throttle Position Sensor Testing, Replacement and Adjustment - Ford Bronco Forum
Old Sep 7, 2020 | 06:34 PM
kevinv10's Avatar
kevinv10
Originally Posted by torq'ta 5 8
I'll do that later, but, IAC, O2 sensor, and TPS were both replaced with new. Still will check codes tho, just in case. Probably a good idea.
Old Sep 7, 2020 | 06:50 PM
torq'ta 5 8
not saying o2 is bad, if your cam, headers, was too much, you would start getting, o2 lean codes, and check your new TPS, and make sure it is meeting the minimum closed voltage(0.6vdc),
Bane270
13
Mar 11, 2014 08:39 AM
Bane270
Mar 10, 2014 02:56 PM
deceptichop
Feb 27, 2011 07:52 AM
nyvp
Apr 30, 2010 07:49 PM
gamudslinger88
Jan 29, 2008 06:34 PM
