injector questions
Old Jan 29, 2008 | 09:29 AM
gamudslinger88's Avatar
gamudslinger88
injector questions
As yall know I am in the process of rebuilding my 302 in my 94 F150, My questions are What injector should I go with. My stock injectors are wore out and have 240k on them anyway. I have been looking at some 24# injectors but will they be too much and will I have to recalibrate the MAF. I am running a 204/214 .448/.472 cam, headers, flowmaster exhaust and no cats so will I need larger than stock injectors.
Old Jan 29, 2008 | 10:37 AM
tfowler306's Avatar
tfowler306
no your stock injectors will handle yout new cam no problem. the 19# injectors are good for 310 hp. youll need alot more than a cam to get that much out of your 302.
Old Jan 29, 2008 | 11:13 AM
gamudslinger88
they are in need of rebuilding. how hard is it too rebuild them? would 24# injectors be too much and make it run rich?
Old Jan 29, 2008 | 11:23 AM
tfowler306's Avatar
tfowler306
24# injectors wont neccearly cause it to run rich if you use the appropriat mass air meeter. so you are adding considerable cost to replacing you mass air meeter as well as new injectors. you shold only go to larger injectors if you are planning major engine mods such as a supercharger. and even adding up to 6 lbs of boost you still would not need larger injectors. just purchase some rebult ones from your local parts house and enjoy your new motor.
Old Jan 29, 2008 | 11:45 AM
Conanski's Avatar
Conanski
What you are proposing is nothing more than a 5.0HO with 1.7 rockers, and that runs fine on 19lb injectors. Bigger injectors on a motor that has not been recalibrated to use them with a chip or tuner won't make any more power but will deliver worse drivability and milage. if your set is worn out the best you could do is buy a new set.
Old Jan 29, 2008 | 01:52 PM
jr32560's Avatar
jr32560
yeah stick with the stock #s -fuel injection is not like the old carbs-from all I've tried to learn-bigger is not always better-even with the old carbs
Old Jan 29, 2008 | 04:20 PM
RC Dan's Avatar
RC Dan
I've never heard of rebuilding injectors. You can clean them out and replace the o-rings outside, but that should be all you have to do.
http://www.fordfuelinjection.com/?p=82
I just...
1. soak them in carb dip for 10 to 15 minutes
2. using a 9v batt. powered test circuit, spray them out with compressed air
3. rinse with carburetor/injector cleaner
4. install new o-rings
And they are as good as new.
Old Jan 29, 2008 | 05:51 PM
Eddiec1564's Avatar
Eddiec1564
What about the cap the holds on the o-ring(intake side), I have a few injectors that the cap is broken appart . Is that a part easy to get? or have the get the whole injector?
Old Jan 29, 2008 | 05:54 PM
gamudslinger88
I just bought a rebuild kit off ebay. Comes with hats,filters and orings for 20 bucks.
Old Jan 29, 2008 | 06:34 PM
Rock Auto Justin's Avatar
Rock Auto Justin
Former Vendor
Hi,
If that kit doesn't work out for your, we have a fair selection of injectors at our website.
Here is a link to help you out.
http://www.rockauto.com/catalog/rafr...&parttype=6224
Hope it helps.
