1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
292 bell housing
Old Sep 5, 2020 | 10:10 AM
Rsross76's Avatar
Rsross76
Cool 292 bell housing
I have a 63 f100 with a 292 3 speed transmission, I bought a 272 y block bored 30 over. I want to hook my 3 speed manual transmission from 292 too it ,will I have a problem with it matching up
Old Sep 6, 2020 | 05:51 AM
Highboy4x4's Avatar
Highboy4x4
They both use the same engine block. You should have no problems.
Old Sep 6, 2020 | 04:40 PM
Rsross76's Avatar
Rsross76
Bell housing
Thanks for your reply
Old Feb 21, 2021 | 10:06 PM
James Townsend's Avatar
James Townsend
5th Gear
I also heard that the 292 housing is bigger than the 223, so the flywheel is larger, so it has more teeth and the distance it is from the starter to the ring gear are different...rear trans/engine mounts are same though. 292/223 have center front mount!
Rockydm
17
Feb 4, 2015 02:18 PM
mj_wyoming
Jan 30, 2010 12:10 AM
61Rat
Dec 6, 2008 09:36 PM
offroad65ford
Nov 11, 2007 02:53 PM
Customcab
30
Feb 7, 2007 09:28 AM
