292 3spd Bellhousing
Old Apr 26, 2008 | 01:33 AM
Rockydm's Avatar
Rockydm
Hello all, I am in the middle of a trany swap, and I need a 3 spd bellhousing that will fit my 292 Y block. Does anyone have one or know where I can find one?
thanks,
Rocky
Old Apr 26, 2008 | 03:47 AM
merten's Avatar
merten
I have one out of a '62 Galaxie. Not sure if it would fit your truck.
Old Apr 26, 2008 | 03:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rockydm
Hello all, I am in the middle of a trany swap, and I need a 3 spd bellhousing that will fit my 292 Y block. Does anyone have one or know where I can find one?thanks,
Rocky
B8C7505A
Fits: 1957/64 F100/250 272/292 w/3 speed or 3 speed w/overdrive (F350 3 speed bell & the 4 speed bell is different).
Also fits: 1957/64 P350/400 with 3 speed manual (P Series = Parcel Delivery)
Cars used a different bell.
EDIT: greensalescompany.com has TWO NOS = new old stock bell housings available = 800-543-4959 (M/F 8-5 EDT)
Old Apr 26, 2008 | 04:00 AM
Rockydm's Avatar
Rockydm
Is it off a 292 and do you know if the clutch was hydrollic?
Old Apr 26, 2008 | 04:18 AM
NumberDummy
Welcome to FTE
1957/60 F100/250's (and others) have a hydraulic setup, 1961/64 F100/250's do not.
The bell is the same either way.
I found 2 new bellhousings, see post above.
Old Apr 26, 2008 | 04:20 AM
Rockydm's Avatar
Rockydm
Thanks Bill, how did you find the bells? When I use the part #'s above, nothing comes up on the inventory search?
Old Apr 26, 2008 | 04:22 AM
Rockydm's Avatar
Rockydm
Never Mind!!! I see the number has changed, and it worked!!
Thanks very much!
Old Apr 26, 2008 | 04:31 AM
NumberDummy
Never Mind!!! I see the number has changed, and it worked!!Thanks very much!
For future reference and FYI.
When you know the part number, you can type it into several obsolete parts sellers websites...try it yourself = greensalescompany.com = type in B8C7505A.
REMOVE any spaces or hyphens when typing parts numbers into websites. Sorry, I'm old fashioned, and sometimes forget to remove those *^$#@ hyphens when listing p/n.
Where to find the part number > >
The 1957/63 Ford Truck Parts Catalog is available on a CD from hipoparts.com / also sold on ebay. The price is about $25.00
I'm using the original paper bound catalogs, but the CD is much handier to use.
The paper catalogs come in 3 bound volumes (two are text, one is illustrations), and most of what's available today (on ebay, elsewhere) are well used and falling apart.
It's also hard to find all three paper bound parts catalogs, usually the sellers only have one or two.
Old Apr 26, 2008 | 09:21 AM
Bob at warsaw's Avatar
Bob at warsaw
I have one that came out of a 59 F100
Old Feb 3, 2015 | 06:13 PM
Mercury59's Avatar
Mercury59
I'm also looking for a Y block bell housing from a truck that had a 3 speed tranny, if anyone knows where to find one, that would be fantastic
thanks
Old Feb 3, 2015 | 06:31 PM
raytasch's Avatar
raytasch
Believe Nothing
OK, I have the bell housing from a 272 Y block out of a 1956 pickup. This has the small transmission mount pattern, three speed, and the rear mounts to the cross member. Shipping would be expensive. Where are you?
And BTW, welcome to the forum.
Old Feb 3, 2015 | 10:14 PM
Mercury59's Avatar
Mercury59
Thanks for the welcome, I've priced shipping on a bell housing from a car from a guy in N.J. and that wasn't bad at all, where bouts are you located, cause I really don't want a car housing.
Thanks,
Mercury59 (Gord)
Old Feb 4, 2015 | 06:46 AM
raytasch's Avatar
raytasch
Believe Nothing
Thanks,
Mercury59 (Gord)
Take this to PM. Upper right corner of this post gives my location, east TN.
Old Feb 4, 2015 | 11:04 AM
Mercury59's Avatar
Mercury59
I'm not sure where in TN. you are, so I used Knoxville as a starting point, turns out it's cheaper shipping from you than the one in N.J. so if you're interested in selling yours, I'd be ok with the shipping cost I got from UPS. How much are you asking.
thanks,
Mercury59 (Gord)
Old Feb 4, 2015 | 01:04 PM
raytasch's Avatar
raytasch
Believe Nothing
Email sent. Guess you don't have enough posts to send receive pms.
