So I was driving and I had exhaust system fluid failure warning come on. I have a 2015 f-250. What causes this and how to fix it. Says I have 50 miles till it will only go 50mph.
Is the DEF full? If so when did you fill it? I had this happen to me but the error went away all; by itself. There is no way for you to clear the code. I don't think a code reader can do it ether. I would however if it gets close to limp mode take it to the dealer. Most of the time folks just do to much stop and go driving and don't let the regen finish. These trucks are made to work . They love to tow heavy loads. They are not much for getting the beer unless you buy lots of beer at a time. They don't like to be babied at all. Diesels are made to be driven. I don't hammer my 15 but I get it up to speed rather quickly. 80 seems to be the speed we drive here in Ca. Hope the truck fixes itself on it's own
Do you have access to a scan tool to scan for DTC(s)? The reason for the notification could be several things. What is the build date?
Short trips, etc. is a concern with EGR and DPF health. I don't see how short trips would affect the reductant system.
How are all the little econo-Box diesels surviving then? I feel like the people who buy the HD diesels generally have some idea what they’re in for but the people buying Mercedes or BMW diesel cars and SUVs just drive them and don’t give the emissions systems a second thought yet they seem to do fine. Some of them even have start-stop which seems really counter intuitive to the health of the diesel. Are these systems better when they’re scaled down or are the smaller versions ‘working’ in their own right?
I don't know about cars and suv's . I do know that trucks must be different because if you don't let the regen process complete enough the DPF will clog and then it's big money to fix. I have never visited the car diesel forum to know anything about them. After the Volkswagen debacle things may have changed for cars. I don't even know if cars use DEF. I do know our trucks and if you don't take care of the DPF it will cause you to push your truck a shop for repairs. Just saying. Those of you who have deleted your truck to avoid this you may just open a Pandora's box of other things that could go wrong with your truck.
Like KPER said, get a scan tool and read the code. Otherwise, you'll just be guessing.
There will be a code of some sort indicating what triggered the def fault. Things like a failing SCR system, bad def injector, failed def pump can all lead to poor NOx conversion, which will trigger a Def fault. It could even be as simple as bad wiring. That happened to me when I replaced my def heater. The failed def heater istelf won't cause a def fault, unless its also below 12 F outside which will result in Poor NOx conversion, and then a DEF fault. But in my case, bad DEF tank heater, as I'm replacing the heater, I cycled the key on with the harness disconnected, and after about 20 seconds of the DEF tank harness being disconnected, I got a DEF fault for some circuit being out of range. This triggered the distance till 50MPH limp mode that I had to have cleared with the appropriate drive cycle once everything was fixed and reconnected.
So you CAN fix this yourself, if you have access to a scantool. An OBDII dongle and Forscan will suffice even, you just need to read the code so you know where to look.
I just want to say thanks to everyone that took the time and replied. Got a lot of good info. My code is gone. Let me just tell you a quick rundown of what happen. So I got the exhaust system fuel failed warning Friday driving home. Posted this Friday night.a few hours latter I tried just topping off the DEF tank. Which was very low. ( I never got the notice of CB 500 mile till empty which used ally happens) After topping off my DEF I posted this thread. Saturday called to get the truck in the shop. Couldn’t get it in till Tuesday morning. So I drove the truck till it went in limp mode and then continue to drive it for about 15-20 miles like that. And while driving the code cleared I was able to exceed the 50 mph. So thanks to everyone.
If you have the means, see if you can have a scantool hooked up to read the codes anyway. There may be a historical code stored that will still showup when scanned. It'd be interesting to learn what the true cause was.
That’s a damn good idea. Cause I just a call back from the dealership. They are saying $1003 to replace the pump. I found the pump on line from a ford dealership in I think Oklahoma for $250 and it does look to hard to diy. Seeing how it seems to be on top of the tank. But still a good idea to find out what the code was.
Dropping the tank and pulling the pump isnt all that bad. you'll want to be able to run your def fluid level close to empty if you can. If not, it can be dropped full, just heavy.
The hardest part is undoing the electrical and def fluid connectors before you lower it fully to the ground.
Did you have the dealer do a VIN check to see if you are covered under the extended DEF heater warranty? Call them and ask them.
Has anyone just taken the bed off seems to be easier to get to.
If you have access to a lift, or 4 guys to help you pull off the bed, it MIGHT be easier to go that route. But really, dropping the def tank aint that bad. I did it myself and I consider myself intermediate at best when it comes to that type of work.
