rough country 1.5 springs
On this 20 F250 I just want to level it and not go to the extreme like I have on other trucks. I like the Carli set up coming out for the 20 7.3 gas but it will be 2.5- 3" and then I have to get the add a pack for the rear to level. Im looking at the Rough Country 1.5 springs and want to know if anyone has use them and do they ride like OEM or softer. I know they wont be Carli quality or as soft, but maybe adding some Fox shocks will get me close.
https://www.roughcountry.com/ford-le...-kit-9285.html
I think your gut is telling you to go with the better quality springs. I suggest you listen. Don’t cheap-out on the ride quality. You’ll feel it literally every time you drive the truck. I don’t think the Fox shocks will help a stiff spring too much. 2-2.5” should be okay for a level. Should leave you with 1-1.5” of rake.
You may want to see these posts in reference to the RC 1.5" springs.
https://www.ford-trucks.com/forums/1...l#post18297333
https://www.ford-trucks.com/forums/1...l#post18298064
JosieGallows
40
02-14-2015 08:18 AM
