Which 1.5" Front Level Kit
Old Nov 10, 2018 | 09:10 AM
HST's Avatar
HST
I'll try again - This was my stock 4800 coil vs the RC 1.5" coil - Name:  amFKYSe.jpg
Old Nov 10, 2018 | 09:44 AM
h20camper's Avatar
h20camper
Originally Posted by Hackenbush
I have 6.2's in all the trucks...... I still have a couple to do.
You must be quite proficient at doing this then.
Old Nov 10, 2018 | 11:02 AM
user 474747383's Avatar
user 474747383
If your were close I'd lend you a pair to try before you bought.
Old Nov 10, 2018 | 11:40 AM
h20camper's Avatar
h20camper
Thanks for the offer. I am fairly close to Fairfax. Was more interested in your expertise of doing the spacer install. How long does it take you now?
Old Nov 10, 2018 | 12:08 PM
user 474747383
Springs or spacer is about an hour, Springs are a little faster 35 40 min. But I use the front end rack at Jerrys Ford at night ( After 8:00 pm) so I can align FE when finished. When doing the spacer you still have to pull the front springs & reinstall. Also the RC spacers are the best fitting out there I've used and the Longer bolts they send are Grade 8 Military Spec.
Old Nov 10, 2018 | 01:55 PM
h20camper's Avatar
h20camper
..... the RC spacers are the best fitting out there I've used and the Longer bolts they send are Grade 8 Military Spec.
Great info. Thank you.
Old Nov 10, 2018 | 08:08 PM
stevebf's Avatar
stevebf
RC 1.5 Springs
With the RC 1.5 springs is there any additional requirements? (i.e. track bar bracket, shock extensions, or anything for the alignment)
My truck is a 2017 F250 6.7L 4x4 with stock springs (no plow package)
Thanks!
Old Nov 11, 2018 | 03:59 PM
keith86's Avatar
keith86
Thanks!
Interested also!
Old Nov 11, 2018 | 05:32 PM
HST's Avatar
HST
For my truck, I had to get 2* caster cams after the RC coils. The axle will shift a bit to the drivers side but it's on 3/4" or so. I didn't worry about it but some folks like to get an adjustable track bar. Most track bar brackets are for 2+ inches so it could go slightly the other way. I never swapped shocks and no problems to speak of.
Old Nov 11, 2018 | 07:54 PM
user 474747383
The Track bar bracket just relocates the mounting point lower so the track bar & drag link are parallel to each other like stock. No need to lengthen or shorten the track bar. The front axle is off set to the drivers side from the factory on all Solid axle 4x4's. Just throw an after market and wider tire on a stock truck and you will see.
All my trucks have 1 1/2" to 2" leveling RC blocks or RC springs and the caster shims in the box in the picture above, Ready Lift Track bar bracket, and Carli sway bar drop kits & Fox 2 1/2" longer shocks and not one of them have any front end problems and any speed or hitting any kind of bumps Empty or towing and we tow Landscape/dump trailers every day.
Good luck.
ArcticCircle
Apr 4, 2018 07:09 PM
BKSMN
Dec 20, 2014 09:00 AM
nikmish
Apr 18, 2014 02:00 PM
justblowin'smoke
Jun 5, 2008 07:40 PM
worknon10s
Mar 22, 2007 10:06 AM
