Window crank removal?
Old Aug 28, 2020 | 03:31 PM
52 Merc's Avatar
52 Merc
Originally Posted by Bob Ingram
Well damn...I can’t find the pin. I’m pulling the Escutcheon away from the door as far as I can and I can just see the end of the crank.
Move the escutcheon away from the handle, not the door.
Old Aug 28, 2020 | 05:18 PM
Bob Ingram's Avatar
Bob Ingram
Doh
Old Aug 29, 2020 | 10:50 AM
Bob Ingram's Avatar
Bob Ingram
That was a big help in locating the pin, thx. However, it won’t come out. I pushed the collar back, put a drill bit in the hole and beat on it with a hammer, it won’t budge.
I soaked it with penetrating oil and will try again later, but I’m afraid I may need to drill it out, or possibly cut the shaft off. The regulator is shot anyway but I was hoping to use the old handle.
I'm not surprised, 72 year old truck will have things that won’t come apart. I’ve been lucky so far, this is the first thing that didn’t come apart after some persuasion.
Old Aug 29, 2020 | 10:55 AM
fordf348's Avatar
fordf348
Turn the handle 180 and try it again
Old Aug 29, 2020 | 10:58 AM
FortyNiner's Avatar
FortyNiner
^what he said
Old Aug 29, 2020 | 11:36 AM
Bob Ingram's Avatar
Bob Ingram
yepper...did that. For some reason there’s 3 holes in the handle.
Old Aug 29, 2020 | 12:04 PM
Bob Ingram's Avatar
Bob Ingram
Woo hoo...the penetrating oil did the trick. The pin came right out, and the handle took some persuading.
and on top of that, the regulator doesn’t look too bad, I think I can fix it. The handle shaft is really loose. I’ll drill the rivets out and see what’s the what what.
twozzie
Aug 24, 2016 03:39 PM
seven up
Feb 7, 2015 05:24 AM
aztsm
Apr 14, 2004 07:55 PM
thaddeus
1947 and Older Ford Trucks
Aug 14, 2000 10:13 PM
