Window crank removal
Old Apr 10, 2004 | 12:17 AM
aztsm's Avatar
aztsm
How do you remove the window crank on a 1970 F250? I'm trying to get the door panel off.
Old Apr 10, 2004 | 12:36 AM
Mil1ion's Avatar
Mil1ion
It takes a special tool.
The Clip in a slot 90* to the crank shaft is horseshoe shaped & it needs to be sprung out.
I have that tool... you're just too far away.
Old Apr 10, 2004 | 12:46 AM
aztsm's Avatar
aztsm
Thanks, where could I get one?
Old Apr 10, 2004 | 12:56 AM
Mil1ion's Avatar
Mil1ion
Someplace that sells KD or Lisle tools.
I found it for you.
You can buy it form one of FTE's sponsors.
http://www.dealsonwheels.com/partsan...part_id/520482
www.macsautoparts.com
Old Apr 10, 2004 | 05:46 PM
heatmiser's Avatar
heatmiser
Special Tool ??
On a FORD Truck!
Was the 70 model different from the rest ?
I have owned the 68,69 and currently the 71 model and all window cranks were removed by removing the screw from the center of the handle and simply pulling it off!
Although, I did have a 70 chevy that had horseshoe clips that required the tool that you mentioned.
Old Apr 10, 2004 | 06:26 PM
KS70's Avatar
KS70
I got a '70 F250 and I use a screw driver to take my window crank **** thing off. Nut driver works good to get the screws in the arm rest off.
Old Apr 10, 2004 | 09:42 PM
aztsm's Avatar
aztsm
Originally Posted by heatmiser
Special Tool ??
On a FORD Truck!
There's no screw. The center is solid.
Old Apr 10, 2004 | 11:38 PM
comet's Avatar
comet
I've bent a coat hangar before and used that. You just need to find the loop end and give it a tug.
Old Apr 11, 2004 | 12:02 AM
Mil1ion's Avatar
Mil1ion
I have used a coarse tooth Hacksaw Blade until I bought the proper tool.
Old Apr 14, 2004 | 06:43 PM
mk's Avatar
mk
My favorite 'tool' for those goofy clips is a pop rivet with the end bent over held with a pair of visegrips. Works great.
mike
Old Apr 14, 2004 | 07:55 PM
xlt70black's Avatar
xlt70black
It seams you have a clean old ford there thats never had the window crancks removed sounds like it still has the aluminum cover over the screw hole it's stuck on with some type of adhesive only thing bad it's a one time cover once you pry it off it's going to distort it i think dennis carpenter sells these covers.
