Window crank removal?
Old Aug 27, 2020 | 06:04 PM
Bob Ingram's Avatar
Bob Ingram
This will go down as the dumbest thread I’ve ever started.
I removed the windows on my 48 F1 so I can rebuild or replace the regulator, and replace the glass. I can’t get the window crank or latch handle off. In the 60s I used a tool that pushed off a snap ring, but I don’t see it.
the service manual just says remove the handle, but not how.
hammer and chisel? Dynamite? C4?
Old Aug 27, 2020 | 06:19 PM
allout5151's Avatar
allout5151
If it is the same as my 51 the chrome bezel behind the handle is spring loaded and a portion of it will move exposing a small dowel pin. Lightly hammer that out and the handle will come off.
Old Aug 27, 2020 | 07:12 PM
3twinridges's Avatar
3twinridges
Ideally, it’s a two man op, one pushes the escutcheon back to reveal the pin, the other uses a small punch to push it through.
JB
Old Aug 27, 2020 | 07:23 PM
firstrider's Avatar
firstrider
They are a ton of fun on a 69 yr. old truck in the salvage yard when it is 28 deg. & snowing .
Old Aug 27, 2020 | 08:02 PM
FortyNiner's Avatar
FortyNiner
This is the basic method for the 48-50 models as well. The dowel pin should not need too much persuasion. I've found a putty knife or a wide blade screwdriver useful to hold the escutcheon ring off the door panel while locating the pin.
Old Aug 27, 2020 | 08:33 PM
Bob Ingram's Avatar
Bob Ingram
Ahhh...I think I understand. Thx
Old Aug 27, 2020 | 11:22 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Or 110 deg. in the cab and 80% humidity.
Old Aug 28, 2020 | 10:05 AM
Brian1950F4's Avatar
Brian1950F4
Speaking of locating the pin, I need one. I have not found it listed in any catalogs yet.
Old Aug 28, 2020 | 02:05 PM
M-1 guy's Avatar
M-1 guy
firstrider has much to be proud offirstrider has much to be proud offirstrider has much to be proud offirstrider has much to be proud offirstrider has much to be proud offirstrider has much to be proud offirstrider has much to be proud of
They are a ton of fun on a 69 yr. old truck in the salvage yard when it is 28 deg. & snowing . Ya gotta dress for the cold
Old Aug 28, 2020 | 02:08 PM
M-1 guy's Avatar
M-1 guy
Gotta dress for the cold
Old Aug 28, 2020 | 02:13 PM
FortyNiner's Avatar
FortyNiner
I'm certain that at least one of mine went missing. My solution was a piece of rod stock from a hardware store. Seems like it was 3/8 diameter.
Old Aug 28, 2020 | 02:40 PM
Bob Ingram's Avatar
Bob Ingram
Well damn...I can’t find the pin. I’m pulling the Escutcheon away from the door as far as I can and I can just see the end of the crank.
Old Aug 28, 2020 | 03:07 PM
FortyNiner's Avatar
FortyNiner
It's there just change your perspective.
Old Aug 28, 2020 | 03:08 PM
firstrider's Avatar
firstrider
How many do you need ? Have some here . Send a pm .
Old Aug 28, 2020 | 03:22 PM
fordf348's Avatar
fordf348
Push it, don't pull it
