Unable to remove from Steering Column
Old Aug 27, 2020 | 10:13 AM
boybowser's Avatar
boybowser
1997 F250HD, I am sure this has probably been covered on this forum but looking for ideas before I take steering column apart again. Am unable to remove key from ignition, unable to move key back to full off position, transmission selector seems okay. When it first started I would be able to play with Steering wheel tilt a bit then key would move to correct position and no issue removing. Should have addressed it then but did not, now I am unable to remove the key or get the ignition switch to the full back off position. Looking for suggestions before I pull the Steering column, I use this truck quite a bit. Thanks
Old Aug 27, 2020 | 03:17 PM
jas88's Avatar
jas88
Turn key to on and depress the button underneath that releases the lock cylinder. Stick a screwdriver in and see if you can then turn to lock as normal. If so, probably a bad lock cylinder. They are cheap but I recommend you get a Motorcraft one - the no-name ones at Advance and Autozone are not good.
Old Aug 28, 2020 | 11:42 AM
boybowser's Avatar
boybowser
I am presuming you mean stick a screwdriver in column, so question I have should the ring gear at end of switch come out also? when out the key moves smoothly from acc to start
MThrasher16
May 4, 2013 08:57 PM
thegap1
Oct 28, 2008 05:35 PM
kjk
May 23, 2004 10:19 AM
henryr5
1978 - 1996 Big Bronco
Mar 2, 2004 09:52 AM
ipb1963
Electrical Systems/Wiring
Feb 11, 2003 11:24 PM
