Key turns, nothing else does.
1988 F150
I had that same issue and found a lot of help on the forums.
Here is your problem IF you have tilt steering.
There is a rod that activates the a box that is bolted to the top of the sterring column.
That rod simply moves back and forth.
However, in a tilt steering column, there is a really weird looking hook piece that the has teeth on one end and a hook on the other with a tiny rod on the end of the hook.
The key turns the teeth, those teeth mesh with the teeth on the weird hooked rod, that in turn pushes the rod that has a hook on the end also that moves a selector in a slot on that box bolted to the top of the steering column.
Chances are, the weird looking hooked rod with the teeth is broken in half. This is very common.
You have three choices, the first two I currently have in operation in two seperate trucks (this hooked piece has broken 5 times in 3 different fords on me, mostly in the winter).
1 - Drop the steering column, relocate the box bolted to the top of the steering column to a convient location and move that lever (slotted hole, you'll see it) with a flat head screw driver to start and shut off your vehicle.
2 - replace the broken piece (most likey the weird hook piece).
3 - replace the steering column. (approx 90 - 110 CDN)
If you choose to replace the hooked piece, I am going to suggest this....
1 - It can be done (I have replaced this dammed piece 4 times).
2 - You will have to pull the steering wheel and remove pieces all the way into the column.
3 - Haynes manual will only get you so far.... I like to refer to my own experiences as 'picking up where the haynes manual leaves off'. - yes you can quote me...
4 - This will take anywhere from 1 to 3 hours, depending on frustration levels.
5 - Cost $13 CDN at a ford dealership.
Sorry, after all the times I have replaced the part, I still don't know what the heck it is called!! I just refer to it as that 'hooked piece that breaks in a tilt steering column'. Dealerships carry it, and can possibly provide a print out of the components (maybe that can help).
If you choose to just reloacte the box, I am going to suggest leaving the key portion in, and removing the rod that connects to the box.
It is far easier to NOT have to explain to the police why and how you can start your vehicle with a screw driver with at least a 'dummy key' dangling in the ignition. Alas, I don't have the luxury of even having a door key for that truck, let alone an key cylinder to insert a dummy key into.
Again, do a search.
Also - if you don't have tilt steering, it will be different, but I assume there is a longer rod that is bent. Never having a truck that did not have tilt and have this happen to, I cannot help you there.
AHHHH, one thing I forgot... No vehicle I have done this on has an air bag. I never tried with an air bag in the steering column, so I cannot help you there.
Let me know if any of this helps, and next time I break it, I will think about making a step by step guide to replacing this darn hooked piece.
Do I need to remove the brace below the steering column, and if so will the column need to be supported or not? Cannot find anything in my Chilton’s past the connecting rod, any idea what it connects to?
