1978 - 1996 Big Bronco
my bronco's steering
Old Mar 2, 2004 | 12:18 AM
henryr5's Avatar
henryr5
Can any one explain maybe give tips or help with taking apart the steering column. I tried to put in the cam for the turn signal but it didn’t work And now the light are affected instead of just the signal not staying without holding it up. So I bought the whole switch assembly, Now how do I get the sleeve around the column where the key plugs in off. I need to remove the sleeve so I can fish the wires down through the column. I have a chiltons but it offers little help.
Stay Warm
Steven
Old Mar 2, 2004 | 05:35 AM
77redf250's Avatar
77redf250
Turn your key to the run position,look under the steering column at the plastic cover just below the steering wheel and look for a hole that doesn't have a screw in it and it's just below the key area. If you take a small pocket screwdriver, punch or something like that---push it up into the hole and it pushes a little "plunger" then pull out on your key and this should remove the whole key/tumbler.
Old Mar 2, 2004 | 09:52 AM
BillyBob69's Avatar
BillyBob69
Just watch that you dont let any of the tumblers fall out. Kind of a pain getting em back in the right order with the springs.
dacampeau
32
Feb 6, 2020 11:42 PM
vidaliaman
13
Jul 19, 2017 01:38 PM
tjmike
Feb 27, 2016 08:19 PM
DoggedTired
Jan 28, 2016 03:29 PM
dmueller71
Mar 31, 2015 08:18 AM
