Inside cab light
Old Aug 23, 2020 | 07:07 PM
jerryst's Avatar
jerryst
Inside cab light
Can anyone tell me what if anything I’m missing from from my cab light. This is what I had when I got the truck. I have rewire the truck and want to set up interior lights.
thanks
jerry
Old Aug 23, 2020 | 07:13 PM
gerrymoe's Avatar
gerrymoe
I don't see the switch that goes in the bezel or any wiring for the light socket
Old Aug 24, 2020 | 12:02 AM
jerryst's Avatar
jerryst
So the switch goes into the bezel? It isn’t like normal car working off open doors.
thanks jerryt
Old Aug 24, 2020 | 04:02 AM
Badmoonreizen's Avatar
Badmoonreizen
You are missing the on/off switch and the wiring pigtail. In addition, you need the push buttons for the doors to tie in with the light.
Regards, Mark
Old Aug 24, 2020 | 04:21 AM
Badmoonreizen
Here's the whole kit from Mid-Fifty, but you can buy the switch and other parts separately.
https://midfifty.com/item.php?INV_ID...te-with-wiring
Regards. Mark
Old Aug 24, 2020 | 09:49 AM
gerrymoe's Avatar
gerrymoe
I forgot about the door buttons to make the dome work off when door closed and on when open. Make sure you download the wiring instructions from the mid-fifty site they sometimes forget to include them with their kit
Old Aug 24, 2020 | 10:21 AM
abe's Avatar
abe
You don't need the door buttons. You could use the switch to turn it on and off as needed. That's what I did to my 54 when I ventured on the Dark Side.
Old Aug 24, 2020 | 10:24 AM
bigwin56f100's Avatar
bigwin56f100
exactly. As a matter of fact, I have owned many 56s with dome lights and I’ve never had a 56 with door switches. Always door switches in 53-55 trucks with interior light but never in a 56
Old Aug 24, 2020 | 10:29 AM
avf100's Avatar
avf100
But the door switches are cool....open the door & voila !! Let there be light !!
Old Aug 24, 2020 | 11:11 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
My 56 has door button switches to turn on the light when the doors open and a slide switch on the light bezel to turn on the light with the doors closed. I added a toggle switch to the light bezel to bypass the door switches when I did not want the light to come on. Just like when I was a teenager and we were stealing hub caps. Remember hubcaps?
Old Aug 24, 2020 | 11:35 AM
56panelford's Avatar
56panelford
You've said many times that you used the Ezwire 21 circuit kit, are you using the stock light switch? I have my dome light working with the switches at the doors and from me aftermarket headlight switch..
Old Aug 24, 2020 | 01:47 PM
jerryst's Avatar
jerryst
I have the door switches. is there a way to make it so when doors are open the light comes on? I can get pigtails but do I need the switch?
thank you
jerry
LSCRX
Jan 23, 2019 02:30 PM
49fordv8f4
Aug 3, 2015 08:29 PM
David1986
6.7L Power Stroke Diesel
16
Jul 26, 2015 01:21 PM
PaytonK.79Ford
32
Dec 11, 2014 11:34 AM
miottimouse
Nov 29, 2008 09:46 AM
