Downstream O2 Sensor Wiring
Old Aug 23, 2020 | 03:20 PM
johnnyo1986's Avatar
johnnyo1986
I bought a 1996 F350 460 cab chassis truck that appears to be a Cali emissions truck (3 O2 sensors and an OBD II) . The infinite wisdom of the previous owners was that unhooking vacuum lines, electrical connections and clipping the o2 sensors were all power adders. So far I've been lucky and found a ton of information and photos on here to get the wrongs righted, except for this downstream O2 sensor. They clipped the plug off what I can only assume is the correct 4 wire harness. I didn't know if anybody has a wiring diagram or know the correct wire colors so I can wire up a new connector. Thanks in advance for the help.
Old Aug 23, 2020 | 06:35 PM
torq'ta 5 8's Avatar
torq'ta 5 8
maybe, bottom left of page
Old Aug 23, 2020 | 09:50 PM
rla2005's Avatar
rla2005
Heated Oxygen Sensor 21 is the designator for the third O2 sensor that monitors converter efficiency. And yes, it is on the bottom left of the diagram previously posted.
charlie00tj
Bronco II
Jul 16, 2010 05:22 PM
stangbanger
Sep 29, 2008 05:13 AM
98-Ranger
1983 - 2012 Ranger & B-Series
Feb 10, 2008 10:01 AM
n_ueland015
Electrical Systems/Wiring
Aug 11, 2007 02:08 AM
