Sponsored by: Real Truck
Transfer flo vs Titan
Old Aug 18, 2020 | 12:15 PM
osris's Avatar
osris
I am looking into replacing my factory tank with a bigger one. Does anyone here think one is better than the other? Looks like transfer flo is a little smaller (57 gal) made of metal and costs a little less, titan is plastic and 65 gallons. I have also thought about a trasferflo toolbox tank that would be plumbed into the existing stock tank and just fill up the stock tank while on the go, thoughts on this as well?
Help me decide!
Old Aug 18, 2020 | 02:20 PM
Just Strokin's Avatar
Just Strokin
I have the Titan 65 gallon tank. Love it!! No problems in the last 6 years it has been installed. I like the fact it is "plastic" like the factory tank. I ahve used 60 gallons from the tank a few times when pulling my 5th wheel with no fuel flow issues. Personally, might be wrong, but think the plastic would be more forgiving than the meatlin accident or struck by something on the road.
Old Aug 18, 2020 | 02:28 PM
osris's Avatar
osris
That makes sense. I am not sure you can go wrong either way, but i just wanted to make sure fit and finish on both were on par with each other, did you install yourself or have it installed?
Old Aug 18, 2020 | 05:31 PM
Just Strokin
I helped a mechanic friend install it...was fairly easy...we did it on this shop floor since his lift was not rated for 8500#. We use the lift to raise the front wheels some and then crawled under it. Took us a couple hours. There are plenty of videos on youtube.
I did drive the truck till it was almost out of fuel prior to removing the stock tank.
Desert Dave
Aug 27, 2018 07:43 PM
austint513
6.7L Power Stroke Diesel
40
Jan 17, 2014 07:32 PM
darren32
Oct 7, 2011 07:30 PM
Leonandlisa
Aug 6, 2009 06:20 PM
GoBigOrange
Jan 9, 2007 11:10 AM
