Abs issues
Old Aug 15, 2020 | 03:34 PM
utahjd1's Avatar
utahjd1
Abs issues
Can anyone point me in the right direction?
someone with a 7.3 had the same codes https://www.ford-trucks.com/forums/1...-of-codes.html
Old Aug 15, 2020 | 04:26 PM
Hartwig's Avatar
Hartwig
I have been struggling with ABS faults for many hours. Check the connectors on the module and lift your front wheels. Tear hard on the wheels forward and backward and up and down and check if the hub bearings are ok.
has anything been changed in the wiring lately?
Old Aug 15, 2020 | 04:30 PM
utahjd1's Avatar
utahjd1
bearings seem fine I did slam on the brakes and locked up the passenger rear a little and the light turned on. I’m going to change the rear abs sensor but I’m stumped because I believe the Speedo runs off that sensor and that’s been fine
Old Aug 15, 2020 | 04:53 PM
utahjd1's Avatar
utahjd1
Been going off from this I’m on page 21 pin point test k and the prongs that’s says to test voltage I have nothing. I test this prong and it lights up I pull the fuse and it shuts off....does the early 03 diagram not relate with a 2004.5?
File Type: pdf
Old Aug 16, 2020 | 03:50 PM
Yahiko's Avatar
Yahiko
When was the last time you flushed the brake fluid?
Old Aug 16, 2020 | 04:05 PM
utahjd1's Avatar
utahjd1
Found the issue the wire chafed/broke before the last connection before it went through the firewall. All fixed no codes or light
Old Aug 16, 2020 | 05:33 PM
87crewdually's Avatar
87crewdually
Good find! Good job too doing the pinpoint test. So many would jump to a bad module.
sand_fiend
Apr 25, 2020 04:06 PM
touchupman
1983 - 2012 Ranger & B-Series
Aug 25, 2006 02:44 AM
ranger61878
17
Jul 25, 2006 05:11 PM
79shovelhead
Mar 26, 2006 10:55 PM
