I would have the ABS codes pulled, then come back here and post up what you find.
You're kinda shootin' blindly w/out a place to start looking.
Those codes should help us -help you get there.
**-last I knew the Autozone where I lived had an ABS specialized code scanner, maybe you have a similar part store nearby?-**
If you have four wheel ABS, the codes can be pulled by a scanner, but not likely a generic scanner. It'll have to be a ford one, or a good one that can communicate with the ABS module.
If you have real wheel ABS, you have to jumper a connector under the dashboard to make the ABS light flash the codes. Unfortunately I cannot remember for the life of me which one to do.. and don't go picking random wires either you'll short something out.
