Coolant Smell
Old Aug 12, 2020 | 09:44 AM
littlegram's Avatar
littlegram
Coolant Smell
Hello - truck is a 97 f350. I have been smelling coolant in the cab when driving for over a year. I replaced the heater core but did not fix the smell. Seems to come from behind the glove box which is why I replaced the heater core. This morning when I started the truck I heard liquid gurgling behind the glove box for a few seconds. I have never had any leaks, no condensation the in cab, truck does not overheat, and entire coolant system was flushed about 1.5 years ago and is clean. Anyone know what else I could check?
Thank you
Old Aug 12, 2020 | 12:00 PM
sandymane's Avatar
sandymane
Gurgling in the cab, in my experience, has always been the heater core. It is highly possible you have a defective one. It is certainly not uncommon to get bad parts from off shore anymore. You can always make sure all your connections are secure but I think you will end up replacing it. Sandy
Old Aug 12, 2020 | 12:08 PM
littlegram's Avatar
littlegram
Appreciate it. I will check connections and possibly replace core again. Like your photo - I was in the 82nd from 95-98.
Old Aug 12, 2020 | 12:15 PM
sandymane's Avatar
sandymane
Nice to meet you brother. 62-65 for me. Benning was C119's Bragg was C123's C130's and C124 Globe masters. "All the Way" Sandy
Old Aug 12, 2020 | 12:21 PM
littlegram's Avatar
littlegram
Likewise - c130's and c141's for me.
Old Aug 12, 2020 | 11:41 PM
Scndsin's Avatar
Scndsin
Originally Posted by littlegram
Hello - truck is a 97 f350. I have been smelling coolant in the cab when driving for over a year...
What engine? All the small blocks (particularly 5.8s) have issues with waterpump to timing cover leaks that puddle as shown below.
It leaks, stinks, boils off & you never see a wet spot & your coolant mysteriously disappears.
No reports on 7.5s or diesels, but worth a look.
Old Aug 13, 2020 | 06:36 AM
littlegram's Avatar
littlegram
It is a 7.5. Appreciate the reply.
Old Aug 14, 2020 | 03:46 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Are you USING coolant at all? Fill your system 100% , drive a few 100 miles and see what the level is at. If you're using it, you're losing it.
Old Aug 15, 2020 | 07:28 AM
littlegram's Avatar
littlegram
Thanks, I will check but coolant level has never been low.
Myfirstnewtruck
1997 - 2003 F150
Dec 4, 2009 06:22 PM
zgiannijonesz
1997 - 2003 F150
Oct 30, 2007 08:43 PM
mhayter
Nov 12, 2006 11:27 AM
wlihntr
Feb 14, 2004 05:06 PM
theboogers
1997 - 2003 F150
Mar 8, 2003 02:54 AM
