Sponsored by: Real Truck
Coolant leaking inside cab
Old Nov 11, 2006 | 03:26 PM
mhayter's Avatar
mhayter
I have coolant dripping below the glove box. Every thing looks fine from the engine compartment. Can you help me? F250 '93 7.3diesel. Thanks
Old Nov 11, 2006 | 03:36 PM
ebolavirs's Avatar
ebolavirs
heater core?
Old Nov 11, 2006 | 03:37 PM
Fishsimion's Avatar
Fishsimion
That would be my guess also... Heater Core
Old Nov 11, 2006 | 03:42 PM
mhayter's Avatar
mhayter
Well this is my first heater core problem. Is this a reasonable DIYS projet? Do you have any tips or guidance? Thanks
Old Nov 12, 2006 | 08:00 AM
stevenn1's Avatar
stevenn1
98% leaking Heater core. 2% Hose issues.
HOSE problem: Could be loose/cracked hose going in/out of heater core if hose/core connection point is inside firewall and not accessable from engine compartment. I have seen this happen 2 times.
HEATER CORE problem: When you turn on the windshield defroster - probably has a sweet smell and clouds up the glass even worse than before. When it gets really bad your front passenger side floorboard will be soaked. You will probably have a slimy film of coolant on the inside of the windshield now. I have seen this happen many times.
I have never replaced one on that specific model before. Save tons of $$$ doing it yourself with a Haynes Manual for $20 & a new heater core for under $30.
Sometimes have to release the pressure in the A/C system (like in the early '80s Ford cars) which will cost more money to fill it again. If you must do this, go to a shop and have them perform an 'E-VAC' (a/c system refrigerant evacuation procedure). They will hook the machine to your a/c system and basically suck out all your freon. Then after your work is complete go to the same shop to fill it - they should give you a discount (if the shop originally sucked out 2.5 lbs and then gave you 3 lbs back, because your system was a little low in the first place, you should only be charged for the 0.5 lbs of freon).
Old Nov 12, 2006 | 11:27 AM
jake00's Avatar
jake00
you might have to take out the entire dash. if so, its do-able, but long n tedious
oxt127
May 22, 2015 12:52 PM
bizzj
Dec 13, 2014 02:45 PM
Headviking
May 17, 2012 10:42 AM
trinogt
May 24, 2002 07:55 AM
