Off grid - What will I need?
Old Aug 9, 2020 | 10:13 AM
67_4_ME's Avatar
67_4_ME
Please post your thoughts about what is necessary to camp off grid, whether full time or camping.
Old Aug 9, 2020 | 10:17 AM
67_4_ME's Avatar
67_4_ME
Originally Posted by [color=#222222
Thanks for the picture of your setup, 67_4_ME, I suspect I will end up with something similar. And thanks for pointing out roof warranty issue, will keep that in mind. One question I have for you is which solar panel kit did you buy before your major battery/inverter upgrade? And did you mount those panels on the roof, or was it a suitcase model that you unfolded on the ground (or the roof), and then plugged the wire in the box on the roof provided by GD? If I could start with something like that and it could be upgraded later that I think would be great temporary solution..
This was installed by my dealer.
https://gpelectric.com/products/over...-charging-kit/
Old Aug 9, 2020 | 10:37 AM
mwheue's Avatar
mwheue
Look at this thread, specifically the last couple pages..
https://www.ford-trucks.com/forums/1...rest-trip.html
Looks like you posted in the above thread?
Old Aug 9, 2020 | 03:04 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That depends on what you think you need...
You can go with as little as cold beer, fresh water, food and means of making a fire. Or, you can go with a full solar system, 500Ah batteries, SeeLevel tank monitors, propane, cell extender, etc...
Your expectations of boondocking might be very different than mine, so in order to receive some detailed and pertinent information, tell us a bit more about your off grid camping intentions, expectations, locations, duration and what you want to have available to you.
Old Aug 9, 2020 | 03:26 PM
HRTKD's Avatar
HRTKD
Originally Posted by 67_4_ME
I have almost the same kit in my trailer. 150 watt instead of 190 watt. It works. That kit is expandable and the additional panels will recharge the battery faster.
I want more than my current system can provide. My batteries are dual 6v Trojan T-105, rated for 225 Ah. In late October, early November I can put the hurt on them overnight running the furnace. I'm not looking to run the air conditioner, but I do want to run everything else without worrying about it. I'll be starting a build thread soon.
Regular travel trailers don't have very large tanks. You may run out of room in the black tank before you're out of fresh water. There are portable tanks for that.
If you plan to use a lot of water, search scraprat's national forest thread for his "bladder" upgrade. Upon his advice I picked up a bladder and a pump. It makes getting water or additional water fairly straightforward.
Old Aug 9, 2020 | 05:12 PM
67_4_ME's Avatar
67_4_ME
This thread isn't really for me, many folks responded to scaprats big adventure thread and we were taking it sideways. That's why I created this thread for folks looking to boondock to get answers from more seasoned boondocks.
I do agree with you it depends what degree of boondocking your going to do.
Old Aug 13, 2020 | 09:36 PM
ATC_F350's Avatar
ATC_F350
What is the best affordable way to measure current draw on a rv? I want to try various things to get an idea on what to do.
Old Aug 13, 2020 | 10:05 PM
scraprat's Avatar
scraprat
Top Answer: 5
I personally have not used one some folks use "Kill-A-Watt meters" to figure the loads.
There are videos on YouTube for them.
Old Aug 13, 2020 | 10:19 PM
HRTKD's Avatar
HRTKD
Over all current draw or the draw of individual items?
Overall: Victron BMV-712
Individual: DC clamp on ammeter
Old Aug 14, 2020 | 07:03 AM
ATC_F350's Avatar
ATC_F350
I was thinking overall. I’m thinking measure basic led lights, then add/subtract various items; fridge, vent, etc.
Old Aug 14, 2020 | 07:22 AM
crewzer's Avatar
crewzer
Exclamation
The Kill-A-Watt meter is for AC loads; it can’t be used for DC applications.
HTH,
Jim / crewzer
Old Aug 14, 2020 | 09:56 AM
scraprat's Avatar
scraprat
Top Answer: 5
HTH,
Jim / crewzer
But if you multiple by 10 that will give you dc load.
So if you have a 3a ac load it would be 30a dc. If you used that for an hour it would be 30ah.
Old Aug 14, 2020 | 09:57 AM
acadianbob's Avatar
acadianbob
The Victron unit isn't horribly expensive and is a great product.
Old Aug 14, 2020 | 11:00 AM
crewzer's Avatar
crewzer
Lightbulb
I honestly doubt it would be very accurate for measuring small loads due to the converter’s low-power conversion losses.
HTH,
Jim / crewzer
Old Aug 14, 2020 | 11:08 AM
scraprat's Avatar
scraprat
Top Answer: 5
Enlighten us then.
If close enough doesn't work for you.
