mufflers
Old Aug 2, 2020 | 07:00 PM
Checker's Avatar
Checker
very close to what I want....Thanks
Old Aug 19, 2020 | 05:27 PM
Checker's Avatar
Checker
Well...put a pair of smitty's on..22 inch and they are very quiet. Maybe they will open up with age like the old glass packs did.
Old Aug 19, 2020 | 07:15 PM
Sickler1's Avatar
Sickler1
Shoulda went with spintech's!!
Old Aug 19, 2020 | 08:34 PM
1956_F100's Avatar
1956_F100
Not to steal this thread, but thanks, I've started looking at mufflers for my 1956 F100 and forgot about those. I'll look at them as well.
Old Aug 19, 2020 | 08:56 PM
Sickler1's Avatar
Sickler1
Just go on YouTube and view some videos on what mufflers your thinking about.
Old Aug 19, 2020 | 10:01 PM
Tedster9's Avatar
Tedster9
I've read a popular setup for flatheads back in the day was no mufflers, just straight pipes all the way to the back. Often cast iron, you know - used for plumbing!
Old Aug 20, 2020 | 09:23 AM
tonyguns's Avatar
tonyguns
I asked my uncle about that after reading this, and he did mention that you don't want to run a large diameter exhaust pipe if you're looking for that "late pipe" roar. I am quoting him directly, he's an old 50's era hot rodder who owns his own collision shop.
That's all I got though, as I am too young to know how to build that myself, but old enough to know exactly what you mean.
Old Aug 20, 2020 | 09:29 AM
Tedster9's Avatar
Tedster9
That's true, a classic error is to run (too) large diameter exhaust pipe, from what I've read.
Old Aug 20, 2020 | 11:32 AM
firstrider's Avatar
firstrider
Have a pair of NOS mufflers connected to the exhaust pipes . Would consider cutting of the pipes to let the mufflers go . Send a PM for pics .
Old Aug 20, 2020 | 12:50 PM
Mixer man's Avatar
Mixer man
Deep throaty sound. 2-1/2" in/out x 22" Flowmaster into a 3" pipe. Best at 2:30 (after it's warmed up).
Old Aug 20, 2020 | 01:02 PM
1956_F100's Avatar
1956_F100
My understanding is larger diameter tubing slows the speed of the exhaust gases resulting in a deeper and louder exhaust note. I could be wrong, but it seems to fall in line with what I have seen and experienced on my cars.
Also, lower horsepower motors will tend to have quieter exhaust notes regardless of the muffler or tubing size.
Old Aug 20, 2020 | 02:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Straight pipes, and under a load:
Old Aug 20, 2020 | 02:37 PM
  #28
Tedster9's Avatar
Tedster9
I like that Ross!
Old Aug 20, 2020 | 05:37 PM
  #29
1956_F100's Avatar
1956_F100
That is an error if the motor makes it's power at lower RPM's. The larger diameter exhaust pipe reduces the velocity of the exhaust gasses through the pipe, thus, reduces cylinder scavenging at lower RPM's. One thing to consider is the diameter of the exhaust should be taylored to RPM range the motor makes it's power in. There's probably more science to it than that.
Old Aug 20, 2020 | 07:14 PM
  #30
Tedster9's Avatar
Tedster9
Well I should be more clear, the exhaust guys say there's no benefit for oversized exhaust pipe? It sounds "better" with the right sized pipes too. I agree that things should be tailored for the intended use. If there's one trend that seems to be somewhat common is peeps bolting on lots of expensive, high performance parts that are optomized for all out drag racing, parts that aren't really very well suited at all for street driving, and just cruising around.
Maalakai
Modular V10 (6.8l)
Aug 30, 2011 09:58 PM
jgoshow
1997 - 2003 F150
Aug 16, 2006 08:01 PM
995.4f-150
Exhaust Systems
May 3, 2005 01:40 PM
Bolivianfuego
Mar 29, 2005 10:13 AM
87carbed
Exhaust Systems
22
Jan 23, 2005 05:34 PM
