Motor shut off while driving. Need help
Old Aug 1, 2020 | 01:08 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
While a friend was driving my truck he said it made a popping sound then the glow plug an wrench light came on then the truck show off an would not crank or do anything. I’m out of town working for another week. Looking for any ideas as to what might cause it to do this or what I might need to check/look at when I get back home.
Old Aug 1, 2020 | 01:28 PM
Visurveyor's Avatar
Visurveyor
Have friend postcodes associated with wrench light.other than that we can play guess what it is. No seriously have him tell or post them himself. Have to have somewhere to start.
Old Aug 1, 2020 | 02:04 PM
05 f250 6 inch lift
Will have to get him to go to my house an get the codes from my scan gauge so I can post them.
Old Aug 1, 2020 | 02:05 PM
bismic's Avatar
bismic
Scangauge is a very poor code reader
Old Aug 1, 2020 | 02:11 PM
Visurveyor's Avatar
Visurveyor
Bizmic didn't say it so I will. Forscan Lite or Torque Pro. These cell phone apps will give you what you need as a 6.0 owner. Forscan a little more in depth than Torque but both work very well.
Old Aug 1, 2020 | 02:35 PM
05 f250 6 inch lift
do they work with iPhone/iPad ???
i know some only work on droid devices
Old Aug 1, 2020 | 03:25 PM
Visurveyor's Avatar
Visurveyor
Yes they, both apps work on Apple and Android products. The difference in the two is the OBD11 Dongle you buy. Android is BLUETOOTH Apple is Wi-Fi. That's it. A very good investment. $30 +/-
Old Aug 2, 2020 | 04:57 AM
Yahiko's Avatar
Yahiko
A POP noise and quit sort of points to the YOU KNOW WHAT.
05 f250 6 inch lift Do you recall if the SCT was changed when you did the work you list for mods?
The 2005 is also one of the years where the STC fitting was an issue. I would be willing to bet the IPR value is going to show up as low and
even unplugging the IPR sensor won't let it start.
How ever that would be the second thing to try after seeing it if will start after letting sit to cool off.
Old Aug 12, 2020 | 06:43 PM
05 f250 6 inch lift
Just got home. Checked my truck an the ECM fuse was blown. Replaced it an it will spin over now. Scan gauge shows P0197 code. I’m not sure what that’s for. Charging up batteries now to see if it will fire up.
Old Aug 12, 2020 | 07:30 PM
bismic's Avatar
bismic
P0197 indicates a short with the EOT sensor or wiring.
Old Aug 12, 2020 | 07:45 PM
05 f250 6 inch lift
I have no idea how to find the short. Might just put new sensor in it. It was working fine til I installed bulletproof diesel oil cooler delete block several months ago. Not water an oil temps always stay even or oil 2 degrees above water temp.
im not sure if it’s possible to plug the water temp an oil temp plugs into the wrong sensors ?
Old Aug 12, 2020 | 07:56 PM
05 f250 6 inch lift
Any idea what would cause the engine control module fuse to blow ???
while driving the truck ???
Old Aug 12, 2020 | 08:04 PM
bismic's Avatar
bismic
A common source for that is a short in the fan clutch or fan clutch wiring. Other things that can do so as well are IPR, GPCM, EGR, and the MAF.
Old Aug 12, 2020 | 09:13 PM
05 f250 6 inch lift
fan clutch wiring is all messed up. Got caught up in fan an got ripped apart. I got fan clutch adapter an a 7.3L fan clutch I’m goin to put on it an get rid of the electrical fan clutch.
cuda66
6.4L Power Stroke Diesel
Feb 9, 2014 04:33 AM
A/Ox4
Jun 11, 2011 05:55 PM
blub
Aug 30, 2007 07:34 AM
Agemenon
16
Oct 12, 2006 12:35 PM
TJG
Aug 28, 2003 08:07 AM
