Charging issue
Old Jul 11, 2020 | 07:09 PM
grangr's Avatar
grangr
Charging issue
I have a 88 F350 4x4 with 7.5 and auto transmission. I am having a charging issue. Changed alternator and battery as well as double checking all wire connections. I do have this loose wire that I cannot seem to find on any wiring diagram. Any thoughts?
Thank you.
Old Jul 11, 2020 | 07:20 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Basically that type of terminal is no bueno, they are OK in an emergency situation for temporary use.
Testing alternator output is always done under load, with A/C on full blast, headlights on HI, stereo etc. Run up the RPM to about 2500 and then measure at the battery posts. Normal charging voltage at idle is 13.8 to 14.3 at 80° F.
It wouldn't be the first time a "new" alternator was defective.
Old Jul 11, 2020 | 08:54 PM
grangr's Avatar
grangr
At idle with all of the items you mentioned on, I am at 12.89 volts at the terminals. Any idea what that extra wire may be? I have had the truck about a month and that wire was like that when I got it.
Old Jul 11, 2020 | 09:44 PM
subford's Avatar
subford
That wire also goes under the clamp on the NEG battery post.
The connector in the photo is C104.
Old Jul 11, 2020 | 10:36 PM
grangr's Avatar
grangr
Great, thank you. I will change that post and connector and connect both ground wires.
Old Jul 12, 2020 | 07:11 AM
Tedster9's Avatar
Tedster9
How To Test Your Alternator
12.89 at idle is too low, although charging voltage will sag a bit under load with accessories running. This is why it's checked at 2000+ RPM, it simulates highway cruising. It's very important that cables and ground connections are clean and tight, and the drive belts are not loose. Original factory battery and ground cables should be replaced at some point even if they look OK. 30+ years is a long time for ground cables.
Old Jul 12, 2020 | 04:51 PM
kevinv10's Avatar
kevinv10
Thank you.
I would trace where that plug goes to. Seems odd to have 2 negative/ground cables like that. Is it possible that wire goes to something else?
Old Jul 12, 2020 | 04:54 PM
kevinv10's Avatar
kevinv10
Subford may have nailed it here upon reflection. Clean the wires, check the color coding on them and follow his instructions. I did not read this post as thoroughly as I should have, and may have spoke to soon.
Johnkimble
Sep 23, 2018 04:19 PM
RedDirtLandscaping
Mar 4, 2010 09:13 PM
triskit16
13
Nov 13, 2008 12:31 PM
mattlundb
Electrical Systems/Wiring
19
Jun 9, 2006 10:57 PM
LowBudget76F150
Apr 20, 2004 06:10 PM
