Charging wire from alternator...
Old Nov 12, 2008 | 06:59 PM
triskit16's Avatar
triskit16
Exclamation Charging wire from alternator...
While I change out my alternator tomorrow I was thinking about replacing/upgrading my charging line from the back of the alternator.
I have a few questions:
-Where does the wire run to? Straight to the batteries?
-If I replace the OEM wire will the warning light in dash still work properly?
-Does anyone have a wiring diagram?
Thanks!
Old Nov 12, 2008 | 07:13 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
It goes into the main engine wiring harness, and then across the top of the engine, into the PASSENGER side battery. What most do when upgrading the amperage is to run a second 4ga wire off the same post to the other battery. I did just this when i put in my 220a alternator the other day.
Old Nov 12, 2008 | 07:21 PM
megawatt00's Avatar
megawatt00
If you want a wiring diagram shoot me a PM with your email addy and I'll send it to you.
What Kris said works very well.
Old Nov 12, 2008 | 07:24 PM
F350-6's Avatar
F350-6
What about running an extra ground off of it? I believe kwik added one to his. Seems to make sense to me.
Old Nov 12, 2008 | 08:07 PM
megawatt00's Avatar
megawatt00
That is a good idea Chris. There is nothing wrong with having more grounding.
Old Nov 12, 2008 | 08:12 PM
PowerstrokeJunkie
The block is already grounded at the front, and at the rear of the passenger cylinder head, and through the motor mounts. But, i didnt see a need for it.
Old Nov 12, 2008 | 08:24 PM
F350-6's Avatar
F350-6
It seems like he went off an alternator mounting bolt to the battery. It would seem to me the shorter path would offer better charging at low rpm's, not that I think you'll have an issue with lower rpm's.
Old Nov 12, 2008 | 08:31 PM
megawatt00's Avatar
megawatt00
Electricity is going to take the path of least resistance. For instance, a short happens instead of all of it going through the smaller grounds, the brunt of it will go through the shortest, largest ground.
Old Nov 12, 2008 | 10:48 PM
bdrummonds's Avatar
bdrummonds
Kris, Did you get a shiny one, or did you go the powder coated route?
Old Nov 13, 2008 | 06:39 AM
Kwikkordead's Avatar
Kwikkordead
Seems like a lot of extra work when the driver's side battery is right there and the two batteries are connected in parallel with (I think) 1g cable.
Anyway, here is the cables that I put on my truck.
Old Nov 13, 2008 | 08:25 AM
PowerstrokeJunkie
Yeah, i got the shiney one from DB. Sucks tho, has yours started to turn gold? from the heat i guess. Anyway yeah the ******* that helped me hook up the cables (who insisted on doing it for me) touched the hot cable to the alternator casing a few times, not shiney there anymore.
Old Nov 13, 2008 | 10:11 AM
AustinS's Avatar
AustinS
You're lucky he didn't fry any diodes on the rectifier.
Austin
Old Nov 13, 2008 | 10:16 AM
SpringerPop's Avatar
SpringerPop
A short of that kind, batteries directly to the case, won't kill the diodes.
They don't get "over-currented" or sustain a counter-EMF voltage spike.
Pop
Old Nov 13, 2008 | 12:31 PM
bdrummonds's Avatar
bdrummonds
Nah, mines still shiny. I disconnected the batts when I installed mine so I would not do any unplanned welding. I have a 6 inch scar on my front bumper from when I installed a new + battery cable set up last year and did said unplanned welding. doh!
