Illuminated Switch Install
Old Jul 8, 2020 | 02:16 PM
SuperDutyBoiler's Avatar
SuperDutyBoiler
Wanting to install a illuminated switch that lights up when parking/head lights come on in my 2005 F350 6.0. Where/which is best wire to tap for "+" illumination on?
Old Jul 9, 2020 | 11:49 AM
krifenbu's Avatar
krifenbu
There is a brown wire in the harness behind the headlight switch that has 12v when the park and headlights are on.
Old Jul 9, 2020 | 12:22 PM
SuperDutyBoiler
Cool. Thanks! It looks like there are two brown wires in harness connector that connects to the switch. Do you know if both will work? Probably should verify with a probe light or volt meter before splicing either...
Old Jul 10, 2020 | 10:18 PM
Yahiko's Avatar
Yahiko
You want the one that is going to the cluster.
I added the Instrument Cluster, Illumination and Radio
diagrams so you can see what wires they all use for
the illumination circuits.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 11, 2020 | 10:14 AM
F350 1990's Avatar
F350 1990
Solved. Also those factory upfitter kits (for your year) work well for other things too, look very clean / pro on the dash (install). Ford / Moto accessories are usually high quality.
HT32BSX115
Apr 25, 2020 09:13 AM
Cowboy1951
Aug 15, 2018 06:37 AM
work.truck
Electrical Systems/Wiring
Dec 14, 2014 08:41 AM
Mitch1407
Feb 21, 2011 05:03 PM
barryg
Oct 20, 2006 02:43 PM
