Another quick Fan Clutch Question
Old Jul 7, 2020 | 02:59 PM
D-rat's Avatar
D-rat
Is the bolt diameter and thread pitch the same on the water pump to bolt up the clutch as it is on the OEM fan clutch itself where you bolt up the fan? I need to get new bolts for the conversion and its' 112 degrees outside, so I'd like to get everything I need before I start.....
Old Jul 8, 2020 | 01:51 PM
1TonBasecamp's Avatar
1TonBasecamp
Back to the top.
I don't know the answer for a fact, but if you are talking about the threaded holes in the water pump's fan "flange" thingy, I don't think they differentiate between a fan only, or a fan with a clutch if that's what you're asking.
Although it does sound as if you're asking for info on two different types of fan clutch? Not sure, but if there is only one water pump listed for your engine over several years, then I would guess the bolt threads are the same.
Or are you asking about the thread size where the fan bolts to the clutch, as compared to where the clutch bolts to the water pump?
If that's the case, then I really have no idea. Been way too long since I had one apart.
Good luck.
Paul
Old Jul 8, 2020 | 03:59 PM
BLK79's Avatar
BLK79
I don't know the answer to that either. Been too long since had one off. Never had to buy/source any either as I always used what was on existing for replacement.
Parts arrive OK?
Old Jul 9, 2020 | 10:52 AM
5851a's Avatar
5851a
Basecamp is correct, I've never had to change a water pump when converting to a clutch fan before. Make sure the bolts you use are not to long and just go through the water pump flange.
Old Jul 14, 2020 | 03:11 PM
D-rat's Avatar
D-rat
Just FYI...the bolts in the fan clutch are 5/16 - 18, and the ones into the water pump are 5/16 - 24 (Fine)
Used 1/2" bolts and lock washers on the fan clutch and 3/4" bolts to bolt the clutch to the water pump. Working good.
Old Jul 14, 2020 | 03:59 PM
1TonBasecamp
Great, thanks for the follow-up. Now we can reference this in the future (assuming we can find it!).
Paul
BigWhite76
Sep 27, 2014 10:33 AM
powder1134
1978 - 1996 Big Bronco
Oct 9, 2006 11:05 AM
spixican07
Jun 17, 2006 09:10 PM
Will Shestart
Oct 4, 2004 09:13 PM
tetraruby
May 21, 2001 06:39 PM
