1977 F150 Automatic Shifter Alignment Issue HELP!
Old Jul 14, 2020 | 05:33 PM
dennis drury's Avatar
dennis drury
Hey guys, Thanks to everyone that replies here. I am just getting into a 77 f150 so I have no knowledge yet. Automatic on the column, 2 wheel drive, power steering. The shift collar is not broken. Shifting never hits gear appropriately except it WILL lock into park okay. Once I find the gear, reverse, drive, neutral, 1 or 2 it will drive, but the shifter is sloppy and I can feel it hitting on the gear shift plate. It shifts fine when the part with the bearing and T-bolts in it is off see pic. Then when I put that part on it just doesn’t shift right. I have checked the linkage and adjusted it and played with it until I am tired of it. I figure somehow I am misaligned somewhere, but don’t know what else to do. I thought it was the piece described above with the bearing and the T-bolts in pic, and it probably is, but the T-bolts are in the slots and it matches up to the shift collar sleeve. So IDK. I took it off and put it back on 1400 times to make sure. Please help me think of something else to do. Next step is to see if I can find an aftermarket column, but I really want this OG one to just work. Any comments would be great. Thank you!!!
